21st May 2020, 10:09 pm | #1 |
Roberts R701
I have just finished repairing this after someone connected the wrong power unit to it.
AM works fine. but I don't get any reception on FM. I replaced both IC's. The original socket was configured negative to centre pin, I've reconfigured it to positive on the centre pin as most modern power supplies are like that. I also fitted an 'idiot' diode to stop this happening again. But I do need help with FM. |
21st May 2020, 10:24 pm | #2 |
Re: Roberts R701
Any circuit?
Frank |
21st May 2020, 10:41 pm | #3 |
Re: Roberts R701
Sorry, no circuits available, from what I understand, there never has been.
21st May 2020, 10:53 pm | #4 |
Re: Roberts R701
Michael
There has been an earlier posting on this radio asking for a schematic. Whilst none was forthcoming, the issue was also NO FM. BVWS #85086, dated Jly 2012, the problem was solved by replacing Q2 which forms a 5v regulator. Good luck Chris |
22nd May 2020, 4:10 pm | #5 |
Re: Roberts R701
Hi Chris,
I've replaced Q2 and the zener (fitted 5.6V) I now get 5V on the emitter of Q2 but still no FM. Atone stage I could pick up radio 3 but it was very faint and very very low gain. Unless of course the diode has to be 5.1V |
22nd May 2020, 9:24 pm | #6 |
Re: Roberts R701
Hi Maurice.
I guess you looked at the earlier thread. If the set uses a BA4424 FM Front End then, the Roberts R250 schematic and Mf spec for dc levels should help. Chris |
23rd May 2020, 11:06 am | #7 | |
Re: Roberts R701
The radio uses a TA7358 and TA8117 This is the data sheet for TA8117N This is the data sheet for TA7358 |
23rd May 2020, 6:09 pm | #8 |
Re: Roberts R701
Hi Maurice.
That will be the tread on this site which read: "Robby, I don't know if you have solved your problem with Q2 but here is my answer. Q2 is used as an emitter follower in a small voltage regulator cct. It's main function is to supply 4.5V to IC's 1 and 2. Q2 is a 2SC3330T/U (NPN) When operational, voltages on Q2 should be (volume at minimum and FM selected) e=3.92v c=6.22v b=4.63 Should you need to replace the zener diode (D1) it is a RD5.1EB but any 5.1v zener of the correct wattage should do! Best regards, Mike" After some research, I attach what is a typical TA 7358 front end with its voltage regulator. You have the data sheet and typical circuit for the TA8117N Hope this helps Chris |
