27th Apr 2020, 10:50 pm | #21 |
Re: A tale of two Bush TV22 LOPT
Hi Dave,
I think that deserves top marks as a work around! I also would not have thought of doing that!! I'm surprised that the frame linearity is so good. All the best Nick |
28th Apr 2020, 9:38 am | #22 |
Well it will do as a work around. I have made the connections tidy and fastened the two transformers to the main frame.
I had a bad case of mains hum from the loudspeaker in this set. I would like to thank L.Lawry-Johns (RIP) for solving the problem. In his Practical Tv article "Servicing TV Receivers" number 3 (1950s), he told me what the problem was. A earthing nut and bolt just below the fuse holders comes loose. This was in my case tightening up result no more hum! |
28th Apr 2020, 4:09 pm | #23 |
Well the set is now like Jack "back in the box". The fold over on the LHS with a white line if I tried to increase the width was caused by the 1k ohm resistor going to the grid of the line output valve. I had checked it earlier and it read 1.1 k ohm. This was a 10% tolerance resistor so I did not change it . I tacked a 13k ohm across it and it took the resistance down to 1.04 k ohms. On switch on no foldover and plenty of width from the control that actually worked correctly and no white line! I measured the EHT and it had gone up to 7.25kV!
Thanks again for the help. |
28th Apr 2020, 4:20 pm | #24 |
Might have to check that resistor on mine, it’s got similar ringing/ fold over problems, and generally looks a bit naff... has been a good few years since restoration now though!
Regards Lloyd |
