Service Manuals, Circuit Diagrams and Data Sheets Wanted If you need help finding service data post a message here. Please do not request or offer data that is available from www.service-data.com |
10th May 2023, 3:12 pm | #1 |
Weir 4000 Bench Power supply circuit required.
Greetings to all.
I see in one of the closed threads that someone was recently able to supply a circuit for a weir 4000 bench power supply. I have exhausted all possibilities for downloads from all the usual internet sources so am hoping someone here once again may be able to help. I am wondering if anyone might be kind enough to pass a copy on to me. I have a 4000 power supply that is constantly outputting 49 volts and is not adjustable. A circuit would be of great use for repair and calibration of this unit. Many thanks and best wishes from south east London (UK) John. |
10th May 2023, 3:37 pm | #2 |
Re: Weir 4000 Bench Power supply circuit required.
If this is the thread you're referring to I suggest contacting Julesomega directly by sending him a Private Message (PM).
https://www.vintage-radio.net/forum/...d.php?t=190750
10th May 2023, 3:48 pm | #3 |
Yes, thank you that was the post I found. I had previously tried to send him a personal message but as a new member I was not allowed to do so until I had made at least one post via the forums
Will do so now. Many thanks John. |
10th May 2023, 4:02 pm | #4 |
PM received and replied
- Julian It's good here |
11th May 2023, 8:39 am | #5 |
A very big thank you to Julesomega who so very kindly sent me a copy of the full service manual. The manual I am sure will be a great help with my repair.
Thank you also to Station X who so very kindly corrected my posting error and gave valuable information. Best wishes. John |
4th Jun 2023, 7:56 pm | #6 |
Location: Limerick, County Limerick, Republic of Ireland.
Just found a slightly sick one of these and was quite happy to find this thread, also as a new member I cannot message before posting but I will now,
Good luck to all in your repairs. |
6th Jul 2023, 1:24 am | #7 |
I find I can upload my Weir 4000 manual here as a PDF
6th Jul 2023, 7:13 pm | #8 |
That should probably be moved to the test gear section, as offered/wanted posts are now deleted 90 days after the last post. https://www.vintage-radio.net/forum/...d.php?t=194886
David |
7th Jul 2023, 2:39 pm | #9 |
Indeed you are right David: my mistake when I was searching for a thread on the 4000. I'll have another go
8th Jul 2023, 2:22 pm | #10 |
I'll be wanting a Weir 4000 now and my Halifax says no!
Chris Williams
