Old 24th Mar 2018, 4:08 pm   #1
MarkyP123
Default Ever Ready Sky Monarch AM/FM radio
I'm new to this forum & joined because of what I bought at an auction this morning for £20, and would like more information. I won the auction for 3 portable radios.
They are an Alba 101, an Ekco portable red/cream transistor radio, and the subject of this thread, an Ever Ready Sky Monarch AM/FM radio.
I have no idea if any of these work as I don't have the right batteries. The Ekco seems quite popular but can't find much info about the other two (apart from on Radio Museum website). The Sky Monarch does not have a back on it unfortunately. Any info would be appreciated. TIA.
MarkyP123 is offline
Old 24th Mar 2018, 4:24 pm   #2
AC/HL
AC/HL's Avatar
Default Re: Ever Ready Sky Monarch AM/FM radio
Hi Mark, and welcome.
The Sky Monarch is quite a rare radio I believe, there weren't many valve portable FM radios made here. You're in the right place for information and help with it though.
The other two are fairly common, separate threads (with pictures if possible) will keep things straight forward.
AC/HL is offline
Old 24th Mar 2018, 4:35 pm   #3
MarkyP123
Thanks, I will do that.
Old 24th Mar 2018, 4:55 pm   #4
MarkyP123
Here are a couple of pics of the Sky Monarch. Not in the best of conditions, but everything seems to be in place, except no back. All dials still work including the wavelength dial, though that is a bit stiff. Can't test it as I'm aware these batteries are no longer available. I've heard of people stringing 10 9v batteries together, but i'm not risking it. Will probably sell on.
ID:	159852   Click image for larger version
Old 24th Mar 2018, 5:27 pm   #5
TonyDuell
I've heard it jokingly (?) said that the Sky Monarch was made so that Ever Ready could sell many (Ever Ready) batteries for it. I suspect with that number of valves that battery life was not that long.
More seriously, 10 9V (pp3 type) batteries in series is a perfectly good replacement for the HT battery in such radios. The main risk of damage to the radio comes from an incorrect LT battery. This was almost always 1.5V in battery-only sets (often consisting of several cells in parallel) and supplies the filaments of the valves. If a higher voltage is used, or the HT battery is incorrectly connected to the connections fo the LT battery then all the valve fillaments will burn out, ruining the valves. About half of the (much simpler) portable valve radios I get have suffered from this.
If you want to get it going (and I think it is worth it) then I am sure people here will help you do it with no danger to you or the set.
TonyDuell is offline
Old 24th Mar 2018, 5:32 pm   #6
Cobaltblue
Cobaltblue's Avatar
Hi Mark
The Sky Monarch AM/FM is indeed a rare set.
Could you advise me of the serial number please.
A member of other forums has been collating the serial numbers of these sets I think this is the sixth one known
Mine can be seen on this page.
http://www.cossor.co.uk/about-me-and...r-battery-sets
About half way down on the left.
Mike T
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is online now
Old 24th Mar 2018, 6:03 pm   #7
MarkyP123
Thanks for the help so far. It's serial number is V 1945. So pleased to know I now have the 6th one known to exist.
Old 24th Mar 2018, 8:15 pm   #8
kalee20
Flipping heck! A Sky Monarch for £20! On eBay it would have gone for 10 times that!
Can you get any history of it, who the original owner was, etc? At the time they were made, VHF/FM coverage was not widespread. And by the time it was, most places had mains electricity anyway, so the market for sideboard battery FM sets was rather small - isolated houses and farms.
I have one, it works well. I'm running off batteries (of course!) via a stabilised converter.
You'll have a few Forum members green with envy...
kalee20 is offline
Old 24th Mar 2018, 8:26 pm   #9
Ed_Dinning
Hi Mark, you can, as has been suggested run the set on PP3 batteries, but if you have the skills there have been numerous designs for mains units to power battery sets such as this. It comes out much cheaper.
Ed
Ed_Dinning is online now
Old 24th Mar 2018, 8:46 pm   #10
MarkyP123
If I use PP3 batteries for the 90v HT, what about the 1.5v LT?
Old 24th Mar 2018, 8:51 pm   #11
MarkyP123
I knew nothing of this radio when I bought it. Thought I made a massive mistake. I thought the transformer was missing until I found out it is a battery operated. It has no back, but I suppose this is easily fixed if necessary. I will try to research who owned it. I think it was a collector of battery radios, seeing as the other 2 I got are battery ones.
Old 24th Mar 2018, 8:52 pm   #12
Cobaltblue
Cobaltblue's Avatar
You can use a couple of D cells in parallel.
You can get away with one the LT current is around 300mA
But longer life with 2
Mike T
Mike T BVWS member.
www.cossor.co.uk
Old 24th Mar 2018, 9:07 pm   #13
60 oldjohn
I would suggest getting the 1.5 v LT sorted before connecting the 90v. A wrong connection here could destroy an expensive set of valves in a fraction of a second. With a new set of PP3s you may get away with 9 batteries I would expect the set to run on 80 v measure the voltage when on load. A new PP3 is around 10v
60 oldjohn is offline
Old 24th Mar 2018, 9:11 pm   #14
Philips210
A very interesting and rare set.
I notice it has a DM70 tuning indicator (magic eye) quite an unusual feature on a battery only receiver.
For my battery valve receivers, I built this power supply design https://www.vintage-radio.com/projec...y-set-psu.html and find it to be very useful
Regards
Symon
Philips210 is offline
Old 24th Mar 2018, 9:53 pm   #15
Philips210
Hi
A couple of pics attached of my battery valve power supply (ref Paul Stenning's circuit in link on post #14)
Regards
Symon.
Name:	psu front.jpg
ID:	159869   Click image for larger version
Old 24th Mar 2018, 9:59 pm   #16
vinrads
Wow! that is very neat Symon was it a specially wound tx Mick.
vinrads is offline
Old 24th Mar 2018, 10:11 pm   #17
Philips210
Hi Mick.
Thanks for that. The mains transformer is actually a standard 0-15 0-15 12VA type. One winding feeds the LT regulator for the valve filaments. The other winding feeds a voltage multiplier to obtain the 90V HT. The circuit details are in the link in post #14.
Regards
Symon.
Old 24th Mar 2018, 10:32 pm   #18
Stuart R
Stuart R's Avatar
I built one of Paul's PSU circuits, the neatest bit was finding a dealer at NVCF* who had some Paxolin sockets that mated exactly with the Ever Ready blue battery plug. Once wired and tested, there's no chance of me accidentally crossing HT and LT connections in my old Ever Ready set.
*Mark, should you be bitten by this Vintage Radio bug, NVCF is a great event to visit for spare parts - or even buy more radios to play with.
SR
Stuart R is offline
Old 24th Mar 2018, 11:00 pm   #19
Philips210
Very nice. That's a good idea using the correct polarised paxolin sockets. It's something I could add to my psu to suit the various battery connection possibilities. As you say, it avoids mistakes when connecting to the radio.
Regards
Symon
Old 24th Mar 2018, 11:00 pm   #20
Top Cap
Top Cap's Avatar
Service data here Mark:-
https://www.service-data.com/section...-monarch-am-fm
only £1.99 and all goes to help the Forum.
Whether the Top Cap is Grid or Anode - touching it will give you a buzz either way!
Top Cap is offline
