22nd Mar 2018, 12:28 pm | #1 |
Roberts RM40 tuning issue
Hi all, I am hoping to restore an RM40.
I've not been inside yet, but when powered up it has a very strange tuning fault . Medium and Long wave no issues. Amp section appears to be fine too. But VHF is odd. I can tune into a strong local station and within a couple of seconds it will drift and try to retune its self to the next station along . Very much like a TV looking for analogue stations when tuning and storing as it goes along. Would this be an AFC issue ? Any thoughts before I get stuck in please ? Also, does anyone have the pinout for the AUX socket so I can run my CD101 through it please. As ever any help is always most appreciated. Brett.
BVWS Memeber |
22nd Mar 2018, 12:33 pm | #2 |
Re: Roberts RM40 tuning issue
Is it a varicap tuner, if so I would check the stability of the tuning voltage supply.
I have just checked and the VHF is varicap with the tuning voltages taken from the stabilised PSU. There is a switch to disable AFC which is probably on the front panel so that is easily tested as the cause.
Frank Last edited by Nuvistor; 22nd Mar 2018 at 12:42 pm. |
22nd Mar 2018, 12:48 pm | #3 |
Another possibility is that the VHF tuning potentiometer has poor contact between the wiper and track. A squirt of suitable switch cleaner and lubricant should resolve that.
22nd Mar 2018, 1:17 pm | #4 | |
Pin 2 chassis. Pins 1,4 output Pins 3,5 input. Make sure your CD player doesn’t overload in the input.
Frank |
22nd Mar 2018, 1:34 pm | #5 |
Brill, thanks everyone, I will give these ideas a go. And thanks for the pinout too. I might run a Bluetooth receiver( and use my phone and spotify) through the radio if input overload may be a problem.
Many thanks . Brett.
BVWS Memeber |
23rd Mar 2018, 6:35 am | #6 |
If the input signal is too strong for the amplifier, it's simple enough to fix, with just three resistors. 100mW ones will fit right inside the plug, even.
23rd Mar 2018, 3:11 pm | #7 | |
I got a few mins last night to take set out of its box. And went straight to the pot and gave it a little deoxit . And the tuning stabilised . I reckon another little blast and leave the set running for a few hours should see it back to its best. Really pleased. Thanks for the help . Brett.
BVWS Memeber |
23rd Mar 2018, 5:04 pm | #8 |
Excellent, it’s a nice looking Radio.
Frank |
