27th Jul 2017, 10:57 am | #21 |
Re: Philco 48-2810
Thank You Mike T.
3rd Sep 2017, 10:32 am | #22 |
Re: Philco 48-2810
Hi again, I have now gotten both circuit diagrams for the Philcoradio but the valve line-up has been changed and the bases have been wired to suit. What line-up would would be easiest to get if I need valves .Would anyone be good enough to send me a valve location in relation to the chassis. It would be very much appreciated. Dick.
16th Feb 2018, 7:38 pm | #23 |
Pilot lamp value in Philco 48-2810 radio
Hello again, Would anyone be able to tell me the value of the pilot lamp in the 48-2810 radio or if it can be bypassed if this value s not available. Thanks again, Dick.
16th Feb 2018, 8:14 pm | #24 |
Re: Pilot lamp value in Philco 48-2810 radio
Hello Dick,
The schematic for this set is available to download on the radiomuseum web site but it doesn't indicate the rating of the pilot lamp. https://www.radiomuseum.org/r/philco_48_2810.html Normally it is possible to work out the rating of the lamp from the circuit but there is a drawing error on the schematic associated with the lamp that confuses things. Are there not any markings on the old lamp? |
16th Feb 2018, 8:28 pm | #25 |
Hi, AllI can read is U.S.A. The rest is burnt. Dick.
16th Feb 2018, 8:42 pm | #26 |
Is the lamp wired in parallel with a dropper resistor in the heater chain? If so, what is the value in ohms of that resistor?
16th Feb 2018, 8:50 pm | #27 |
On a similar Philco I have somewhere in the loft the pilot lamp is wired across the filament tap of the rectifier. (35Y4)
On that set it was a No 47 lamp which was rated at 6.5V 0.15A It may be the same on this set. Cheers Mike T
16th Feb 2018, 8:54 pm | #28 |
Ah just found this data for the 35Y4
Cheers Mike T
16th Feb 2018, 9:25 pm | #29 |
Hello,
The radiomuseum entry suggests it is a 35Y4 rectifier and if so this is correct then according to this https://frank.pocnet.net/sheets/049/3/35Y4.pdf it uses a No40 or No47 dial lamp. From this http://www.radiodaze.com/dial-lamps/ both No40 or No47 dial lamps are 6.3V 0.15A. The situation is slightly complex because the anode current usually passes through the dial lamp so if the anode current is over 50 or 60 ma then you need a resistor in paraallel with the lamp. https://www.radiomuseum.org/tubes/tube_35z5gt.html The 35Z5 is basically the same tube with an octal base. http://www.philcorepairbench.com/blo...open-filament/ Yours, Richard Last edited by Mr Moose; 16th Feb 2018 at 9:35 pm. |
16th Feb 2018, 9:51 pm | #30 |
Not knowing parts availability there for a #47 lamp, I have one I can send you, NOS for the cost of shipping.
17th Feb 2018, 1:29 am | #31 |
In view of what Mike T has posted I have re-visited the circuit and decided that perhaps there is not an error. It is where the rectifier takes its anode connection that looks odd but it is possibly done to keep the HT down for the American valve design.
17th Feb 2018, 2:13 am | #32 | |
When I restore a set of this type, I install a 1 watt 220 to 330 ohms across pins 2&3 of the 35Z5 to preserve the valve. |
25th Feb 2018, 2:34 pm | #33 |
Philco Radio 48-2810 question
Hi again, Is there any way that I can substitute readily available valves to get my Philcoradio working again, or is that a very stupid question. Dick.
25th Feb 2018, 2:56 pm | #34 |
Re: Philcoradio 2810 question
The first 2 are B8B loctal base 14S7 & 7B7, the rest are Octal, 12Q7, 50L6, 35Z4
Though some are not common you should be able to buy them all. There are not many equivalent numbers for these series 150mA heater valves. You could convert it to parallel heaters and use 6.3v valves with a transformer. But why do you want a set of valves, they are usually very reliable. How do you know that it is only the valves that you need? What is wrong with set? |
28th Feb 2018, 7:46 am | #35 |
Have frightened Dick off? If so, sorry, but I thought the questions sensible.
28th Feb 2018, 10:16 am | #36 |
It was a reasonable question Sam .
3rd Mar 2018, 4:39 am | #37 |
Come back Dick, we have suggestions for you.
Perhaps I should change my name to Fred Stopper, seems to happen a lot. |
4th Mar 2018, 12:09 pm | #38 |
Hello again friends, My problem is that I can follow a schematic very well, but, when I wind up with a deviation of valves with different heater and other connections I loose confidence. Not having a background in anything electric or having anyone personally to ask I hope you can see my plight. I love your forum and I do not scare easily.
We are still friends Boater Sam. Dick. |
4th Mar 2018, 12:49 pm | #39 |
What valves are fitted in your receiver?
Lawrence. |
4th Mar 2018, 6:37 pm | #40 |
Hi again, The valve lineup is as follows 35y4, 35l6, 12q7 , no number, and14s7.The mains dropper is open circuit and the pilot light is blown. If I try it on 110voltswill I have to bridge the pilot light with something to create a circuit.? Dick.
