Old 4th Nov 2019, 11:53 am   #1
See_Mos
See_Mos's Avatar
Default Philips 209U R18
Hi All,
I have a Philips 209U with a damaged R18, the inrush resistor for the heater chain.
Does anyone know the cold and hot values or any ideas about a replacement please?
Obviously the set isn't worth much so cost could be an issue.
See_Mos is offline
Old 4th Nov 2019, 12:08 pm   #2
ms660
ms660's Avatar
Default Re: Philips 209U R18
5k cold, 160 ohms hot (approx.) according to the Trader sheet.
Check the thermistor data on the electrojumble site for the nearest specs if looking for a NOS or a good used replacement:
http://www.electrojumble.org/techdata.htm
Lawrence.
ms660 is offline
Old 4th Nov 2019, 12:23 pm   #3
Herald1360
Herald1360's Avatar
Confusion for a while- there is no R18 in the Philips data. So.... Trader then.
R18 is likely a NTC thermistor of some sort- it's there to protect the scale lamp from switch on surge current through the heaters. The lamp is an odd 25V 100mA type. If you can't find any useful info on R18 (bear in mind unless it's open circuit, it can look pretty distressed and still be OK electrically) then I would suggest taking it out of the chain and fitting a value of R18 calculated to give the right heater current. The lamp could be fed from a dedicated series capacitor dropper straight across the mains or even its own small 24V transformer. If the lamp is a common size/shape you could use any voltage ~2.5W rated lamp with suitable supply arrangements.
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 4th Nov 2019, 12:37 pm   #4
See_Mos
See_Mos's Avatar
Thanks Lawrence, I should have read the Trader sheet more carefully!
R18 is an NTC and it is broken in two so yes it's definitely faulty.
I have 120 and 240 volt MES lamps so another option would be to put the lamp across the heater chain to dim it down a bit and use a readily available NTC or even a fixed resistor to replace R18.
See_Mos is offline
