Old 20th Jul 2021, 4:35 am   #1
tinkera123
Default Marconi R1155 history
Hi all,
I have a Marconi R1155A. Its Serial number is 28760.
Is it possible to trace some of its history? ... ie where it was used? In RAF? Or stock? How did it get to Australia?? etc Do these Records exist and are they accessible??
Just a bit of background ... my R1155 has the DF stripped out except for some snipped off wires ... otherwise it seems to me to be quite original. Has AM badge, Jones Plugs, early Tuning control, good colours in frequency ranges, original valves and covers, shielding, stamps etc ... however, the wiring insulation is brittle and all caps are old etc..
As yet I haven't started any restoration work ... still in process of checking components, circuitry etc to make sure I know what I have. But, I can see that any removal of parts for replacement or checking is going to cause problems with wiring insulation ....
I know the general history, but nothing about this individual radio. Any help appreciated.
Cheers, Ian
tinkera123 is offline   Reply With Quote
Old 20th Jul 2021, 10:03 am   #2
HamishBoxer
HamishBoxer's Avatar
Default Re: Marconi R1155 history
Welcome to the forum Ian! Not sure about tracing the history of a particular set, be very interesting if you could.
I have 3 of these sets and thankfully all but untouched, it was common that the DF side was removed, a bit like 19 sets with the B set gone.
The rubber wiring will need replacing and there is an excellent book on restoring by I think, an Australian chap.
HamishBoxer is offline   Reply With Quote
Old 21st Jul 2021, 1:29 am   #3
tinkera123
Hi HamishBoxer,
Yes, Peter Holtham's book ... I have searched a few sites for his book, but it seems 'unobtainium' so far.
There is a lot of info on web, some relevant to me, some not. Still trawling through web pages and trying to formulate a plan.
A question for those who have been down this path already ... the adjusting slugs, eg in IF cans, other tuning slugs etc, have been sealed in position with a lacquer of some description. I have run into shattered slugs previously and want to be forewarned with these ... what have people used to soften/remove the lacquer without damage to Formers etc.
Ditto ... any advice re tuning trimmer caps which have been sealed with red and orange paint(?).
Thanks, Ian
Old 21st Jul 2021, 9:50 am   #4
HamishBoxer
Hello Ian,
Yes that was the excellent book and I think possibly there was a later version of it.
Re the slugs etc, normally if if not already been got, they do not need re alignment.
I have done many restorations of valve equipment and very few have warranted alignment.
I could only suggest if needed any adjustment on the trimmers, possibly paint remover or nail polish remover might be worth a try.
Old 21st Jul 2021, 3:43 pm   #5
ex seismic
You email Peter direct for a copy of his book.
Gordon
ex seismic is offline   Reply With Quote
Old 22nd Jul 2021, 12:21 am   #6
tinkera123
Thanks, I will chase down an Email address. Ian
Old 22nd Jul 2021, 11:22 am   #7
Julesomega
Julesomega's Avatar
Yes, unfortunately now unobtaniable. Searching the forum for Peter Holtham finds that he used to have a blogspot for his 1155 work and book but that has now gone
- Julian
It's good here
Julesomega is offline   Reply With Quote
Old 23rd Jul 2021, 1:47 am   #8
tinkera123
Re Peter Holtam book - here's hoping that some-one reading this Thread has one surplus to their needs ... ... preferably in Oz, as postage costs from overseas are usually very high.
Cheers, Ian
Old 23rd Jul 2021, 7:31 am   #9
Peter Holtham is a forum member, but hasn't logged in for over two years.
His forum username is pnh0001. He doesn't accept emails via the forums, but you could try a PM. He has a notification set up so he'll receive an email to alert him to the fact he has a PM.
Keep the soldering iron hot.
Old 23rd Jul 2021, 8:14 am   #10
lesmw0sec
Attached is some pictures of an R1155 rescued from a skip. Prior use had seen it drastically 'improved' well before it was thrown out, necessitating a complete strip and re-wire. Since a great deal of original items had gone missing, I added a 6V6 output stage, internal PSU and small speaker. For the last five years this has given good service beside my bed. The valves are all the original and even older than me...
ID:	238105   Click image for larger version
ID:	238106   Click image for larger version
lesmw0sec is offline   Reply With Quote
Old 24th Jul 2021, 12:38 am   #11
bill knox
Hi
I have a copy of Peter Holtham's book on restoring the R1155, I bought it a few years ago and if my memory serves me correctly it cost me £25 and £25 for delivery from Australia
I have an address in Australia,
21 SHERBORNE PLACE
CHAPEL HILL
QLD 4069 AUSTRALIA
His email address is
pnholtham@optusnet.com.au
I have not spoken to him for some time so he may have moved, It may help with postage if you can get someone else to buy a book as well, as I seem to remember that it was the same postage to send 1book or 2.
Hope this is of some help
Bill
bill knox is offline   Reply With Quote
Old 24th Jul 2021, 1:10 am   #12
tinkera123
Hi lesmw0secs,
Yes, a lot of my stuff has also come as Dump rescues. That front panel must have been a challenge ... looks a heck of a lot better now ... My skills are more with the internal stuff. I bought this radio, so it is in much better condition. The front panel will be cleaned, maybe a couple of small panels to hide holes, or dummy switches if I can match the look of the removed DF stuff, re-arrange Plug ares etc..
Internally ... well, who knows at this point. Pieces of wiring insulation are falling off already when I turn the radio over to trace out wiring ... ... but I have plenty of time and patience.
Station X .... thanks, I might try the PM route, but sounds like Peter H may not want to be disturbed with this.
Cheers, Ian
Name:	Marconi R1155 Thumbnail #1.JPG
ID:	238133   Click image for larger version
Name:	Marconi R1155 Thumbnail #2.JPG
ID:	238134   Click image for larger version
Name:	Marconi R1155 Thumbnail #3.JPG
ID:	238135   Click image for larger version
Name:	Marconi R1155 Thumbnail #4.JPG
Old 24th Jul 2021, 8:00 am   #13
lesmw0sec
Tinker - it looks like yours has been 'improved' to the same extent - but at least not so much corrosion! Plenty of diagrams on the web to assist with re-wiring, I suspect that the decoupling caps have also had it by now.
Old 24th Jul 2021, 8:08 am   #14
merlinmaxwell
merlinmaxwell's Avatar
Why the different tuning gang spacings?
Old 24th Jul 2021, 9:34 am   #15
HamishBoxer
Those .1uF,s will certainly be duff in the cans. 3 caps per can.
When I bought my book, I certainly do not remember high postage costs.
Old 24th Jul 2021, 10:22 am   #16
Oscillator stability I would have thought.
The Collins TCS-12 uses the same trick, in that one the value of the oscillator tuning capacitor is higher than those in the RF section, so far as I can make out.
ms660 is offline   Reply With Quote
Old 29th Jul 2021, 12:36 pm   #17
Julesomega
Julesomega's Avatar
I emailed Peter and he has copies of his book still available but is not planning a revised edition. He charges UK£45 incl postage to the UK. He will be happy to ship several copies together so I am hoping a few other members will show their intention to buy and will put down a deposit on the basis of which Peter can confirm the total cost including shipping. I will buy a few more copies for members who may not see this til later, or BVWS members, and any left over I will sell outside the forum
Assuming each book is under 0.5kg the additional UK postage will be £2 so I am hoping the reduction in international shipping costs will make this worthwhile.
Pleae email or PM me for payment details; I suggest £5 deposit
- Julian
It's good here
Old 27th Aug 2021, 1:20 pm   #18
Julesomega
Julesomega's Avatar
I ordered three copies from Peter and they arrived this week, so I have two copies for offer to other members here, now posted under 'offers'
- Julian
It's good here
Old 29th Aug 2021, 8:18 pm   #19
John KC0G
So, which edition of the book is Peter shipping?
Thanks and 73, John KC0G
John KC0G is offline   Reply With Quote
Old 29th Aug 2021, 8:33 pm   #20
Cobaltblue
Cobaltblue's Avatar
From the pictures in the items offered (now closed) its the 3rd edition.
Mikd T
Don't care if it was a bargain why's it in my kitchen
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is online now   Reply With Quote
