25th Aug 2018, 11:44 am | #1 |
Codar mini clipper.
Hi.
Has anyone any details of chassis dimensions of the mini clipper made by Codar in the 60's? I have all other parts for kit in old box, chassis must have been used for something else. I would like to build this after many years. Thanks, Mick. |
25th Aug 2018, 12:41 pm | #2 |
Re: Codar mini clipper.
I would Guess 6 inch by 4 inch after a quick Google.
25th Aug 2018, 12:51 pm | #3 |
Hi thanks could not find after searching many times not asking google the right questions thanks Mick
25th Aug 2018, 1:23 pm | #4 |
You are very welcome Mick.I am guessing though looking at the pictures found.
25th Aug 2018, 2:01 pm | #5 |
There is an under chassis photo on this page which shows an IO valve base, from the dimensions of that could you work out the chassis size?
http://vintageradio.me.uk/kits/codar_miniclip.htm
Frank |
25th Aug 2018, 2:23 pm | #6 |
There were two Mini-Clippers. The first one, (1961) used a 1T4 B7G valve and octal based plug-in coils (presumably the earlier Denco ones). Later, for some bizarre reason, there was a 2-transistor add-on audio amplifier conversion kit to turn it into a hybrid radio. Quite why they used two OC71s instead of say another B7G valve is a mystery, given that back then, OC71s would have cost more than a valve. Later on, because of the cost and poor availability of HT batteries, they dropped the valve Mini Clipper and brought out an all transistor one, I think with B7G plug-in Denco coils.
The Codar Company is something of an enigma. They suddenly appeared on the scene, brought out quite a range of sets that could be bought as kits or ready made, and were advertised extensively. They had their moment in the sun, then disappeared without a trace. I guess it was quite a small outfit which did remarkably well to design, build and market such a wide range of equipment. Their notes were typewritten, the circuits hand drawn, photocopied and stapled together. All very low budget. Their equipment seems quite cheap when view through the rose-tinted specs of nostalgia, but when adjusted for inflation, it certainly weren't. The CR70A - a fairly basic general coverage receiver was, as I recall, £19.95, which - when adjusted for inflation - equates to £425 today. That said, as with all Codar gear, they must have sold in quite large numbers. Five valves including the rectifier, plus an OA81 diode detector/AVC, with a BFO and S meter. The Codar styling was quite appealing to my eyes, with a home-brew aura about it, but even by the standards of the day, their mains powered equipment - notable the AT5 power supply - had a few safety shortcomings. Codar kit still often pops up at rallies, but the ones that use Denco plug-in coils are often missing the coils, without which they're just an ornament. Enjoy building the Mini-Clipper Mick!
25th Aug 2018, 3:07 pm | #7 |
That is the link I used Frank,hope not too far out.
25th Aug 2018, 6:22 pm | #8 |
As David says, the Company is quite an enigma. Lots of people liked the look of the sets despite relative simplicity but they were not so available re the price I agree
Quite a number of threads but one started by Grid Leak... The History of the Codar Company [16/11/12] sums things up I think. Southwick is not far from here in Bexhill and my brother-in -law lives at Shoreham. I'll get him to ask around. Dave W Last edited by dave walsh; 25th Aug 2018 at 6:30 pm. |
25th Aug 2018, 8:36 pm | #9 |
I have quite a bit of original Codar information somewhere. I will look it out.
I still have my T28 receiver (which was companion to the AT5 transmitter). I had many hours of enjoyment from it. |
26th Aug 2018, 11:52 am | #10 | |
Don't forget the B9A connecting plugs used on the lead from the PSU to the AT5, with a male plug at each end, very nasty! I have one piece of Codar gear that I have no info or even a model number for, it's a station controller with a pair of mains-powered relays with DPCO contacts, a front panel RX/TX switch and a neon which I think comes on when transmitting. It also has a flying lead with a push-button switch to give a PTT action and a set of Belling-Lee aerial sockets to switch the antenna between RX and TX. The footprint is a bit bigger than an AT5, IIRC. Anybody recognise the description, I will take some snaps of it. 73 Roger/G3VKM |
26th Aug 2018, 1:01 pm | #11 | ||
If the AT5 PSU was switched on without the B9A male plug which carried the HT/LT, (HT is 270V plus 150V stabilised), being plugged into to the AT5, the pins would of course be live as the unwary occasionally discovered. Back then, any shortcomings would have been considered to be not the design, but the lackadaisical carelessness of the operator. It should of course have been a female socket on the power lead, with a male plug on the At5 chassis, but even then, not entirely safe. The mains switch on the PSU was just a slide switch, and some of the internal wiring was perilously close to the chassis. I had one for some years, when I lived in Sheffield in the late 1970s and had fun with it on 'Grandads' Band' (160M). The late Arthur Carpenter designed the 'Ten-Five' transmitter (10 Watts five valves) which appeared in P.W. and was almost identical to the AT5. I'm not sure which came first. It seems a tad bizarre today, that the favoured band for mobile back in the 60s & 70s working was 160 Metres - probably the least convenient from an antenna point if view, but typically, amateurs would make a loaded whip, drill a hole in the chromed rear bumper of their car, fit an AT5 under the dashboard, powered by the 12V transistorised Codar PSU. Very neatly styled and a lot packed into a small cabinet. I'm not sure it was a good idea to stack the transmitter on top of the PSU with all the heat drifting upwards, and the consequent drift in frequency, but nobody seemed to care about such trivialities back then.
26th Aug 2018, 1:07 pm | #12 | ||
https://www.ebay.co.uk/itm/CODAR-TRA...UAAOSw66NbY0tc No discussion about that particular eBay item please for obvious reasons!
26th Aug 2018, 3:18 pm | #13 |
That is different to the 12V mobile PSU I had. Possibly an earlier version, as mine was more compact - although not of any practical use to me!
Yes, from today's point of view putting an AT5 and T28 in a car seems quite odd. But presumably they fitted on the glove shelf? |
26th Aug 2018, 4:01 pm | #14 |
I use a Codar balanced coil in my rather open-plan ATU. I'd love to know which product it was designed for.
26th Aug 2018, 4:21 pm | #15 | |
Happy /M Days! |
26th Aug 2018, 4:25 pm | #16 | |||
73 Roger |
