3rd Oct 2017, 11:32 am | #1 |
Grundig 5040W tuning dial back plate
I am currently restoring a Grundig 5040W (not 3D). The paint on the tuning dial backing plate is parting company with the metal, and has flaked away in places leaving gaps. I need to re-paint the whole backing plate to do the job properly - does anyone know what sort of paint would be best?
3rd Oct 2017, 6:15 pm | #2 |
Re: Grundig 5040W tuning dial back plate
I had a broken dial glass on a Grundig 5040w3d, it was only cracked in two so it glued perfectly but the scale paint showed the break, I touched up using acrylic model paint which made the break invisible.
3rd Oct 2017, 10:40 pm | #3 |
Okay, I once fixed a radio's cracked glass, but it depends how good you are with digital stuff. Anyway, I had a cracked and flaking glass and I scanned it in a scanner in 2 bits and joined it on Paint Net. a free photo editing software. Once done, I also touched up the flaked bit with the software so I had a clean image with the crack brushed out. Mirror flipped the image left to right and took it to the printer (Minuteman Press - my local one, they have branches all around UK) and told them to print in the dimensions I wanted. They could not print onto glass or plastic, but they did it on a clear sticker. Remember I mirrored it? I stuck it to the back of a perspex sheet so it will be the right way round when looked at from the other side. Cut it to shape, drilled the holes and I had a brand new panel.
4th Oct 2017, 7:01 am | #4 |
I dont think the OP needs to repair a cracked dial glass, he just needs to re-paint the flaking paint on the backing plate.
I would make sure all the old paint is removed and respry with a primer and colour to match the original as close as you can. I normally go to Halfords to get my spray paint, take the old backing plate with you (before all the old paint is removed) so you can get a colour match. If it is white, beware modern white spray paint often looks very wrong, I go for a subtle off white. Mike |
4th Oct 2017, 8:26 am | #5 |
Sorry I read the post wrong
