28th Sep 2017, 5:01 pm | #1 |
Bush VHF80 valve radio
Hi Guys, I wish to ask regarding this model radio as I've bought a fully restored one from a guy. It works really well on all wavebands, but does seem to have a background hum. I've been told it's normal by the guy I bought it from. Please can anyone advise if that's correct or not?
Kind regards, Mick. |
28th Sep 2017, 5:20 pm | #2 |
Re: Bush VHF80 valve radio
All depends on how much but yes most of the standard radios built in the 50’s had a small amount of hum.
It’s not normally noticeable at normal listening levels when sat a few feet away from the set.
Frank |
28th Sep 2017, 5:59 pm | #3 |
The Bush VHF80 is an AC/DC mains set, so it uses half wave (rather than full wave) rectification for producing the DC HT supply, generating a 50Hz ripple on it, which may well be heard on the audio output. 50Hz ripple is more difficult to filter out than the 100Hz ripple in AC only sets.
AC/DC sets use series connected heater chains, rather than parallel. Consequently, the Heater-Cathode voltage differences in the valves are therefore greater and 50Hz hum may be induced into the audio via this path. Because of the above, residual hum on the audio is invariably more noticeable on AC/DC sets. |
28th Sep 2017, 6:07 pm | #4 |
I'm not familiar with the VHF80 though I have its successor the VHF81 here - and it doesn't hum.
if the 80 is anything like the 81 it will have been designed to benefit from the noise- and interference-free background that FM transmissions can offer. Bush wouldn't have wanted this to be spoiled by mains-hum! I'd be checking for dried-out smoothing electrolytics as the #1 issue. Similarly, anything that increases the HT current draw [leaky 'that capacitor' or leaky decouplers] will mean more ripple on the HT line, and also [assuming your output transformer has a 'hum bucking' tap on the primary] imbalance of the current through this winding meaning the hum-cancellation will be less-than-optimal. Also check the emission of the rectifier - if it's low then you'll get more ripple. |
28th Sep 2017, 6:15 pm | #5 |
Hum cancelling sound output transformer in the VHF80 plus 40uF reservoir according to the Trader schematic.
Lawrence. |
28th Sep 2017, 6:42 pm | #6 |
Is it possible to confirm what the restoration consisted of?
Frank |
28th Sep 2017, 7:27 pm | #7 |
Quite so.....'fully restored' might mean a good polish and a vacuum out! Unless you buy a set from a known supplier who restores sets for a living, it doesn't follow that any major work has been carried out. I've seen original sets with no work carried out advertised as 'fully working'. The fact that it switches on, lights up and receives some radio stations is good enough for some people. Due to the 'double smoothing' arrangement and the anti-hum winding on the transformer, the hum level on these sets is very low.
28th Sep 2017, 10:51 pm | #8 | |
Cheers, Neil |
29th Sep 2017, 2:41 am | #9 |
Hi guys.
Many thanks for all your inputs regarding this matter, I'm going find out what work has been done to it as I noticed a lot of new capacitors inside when I took the back off to have quick look. |
5th Oct 2017, 12:19 pm | #10 |
Re post#4
The VHF80 and VHF81 have exactly the same chassis. The difference between them is the VHF80 uses a plastic cabinet and the VHF81 a slightly larger teak case. You can swap the chassis between them after changing the dial glass and its supports over-the VHfF81 has slightly bigger glass and its supports are different but it is an easy job to do. Be aware though that the cabinet on the VHF80 is made from very thin plastic and can be easily cracked if the chassis removed which seems to give it extra rigidity. I have restored several 80s and 81s and hum has never been a problem. For their time these were top of the range sets and give a good account of themselves even today once the normal age related issues have been dealt with. I use an 81 daily and certainly on FM there no trace of noise or hum even when the volume is turned up full. Although I have found the main smoothing caps used in these sets to be very reliable a quick check can be made by tacking a high voltage electrolytic across the HT rail to see if it does cure the problem In addition to the other suggestions made here you may want to look a bit more closely around the UABC80 and the volume control to make sure that cables carrying the low level AF are in good condition and have not been rerouted close to any sources of hum such as the heater chain |
