23rd Aug 2006, 11:45 am | #1 |
Gizmos.
Hi guys.
I aquired a couple of gizmos recently as a job lot with an old Ferguson reel/reel. The first is a 'Metrostrobe' tape recorder speed tester. Either every reel / reel machine I've had since is running fast or slow, or it's faulty, or I'm doing something wrong. Has anyone any experience of these? The second is a continuous magnetic tape cassette made by 'Radio Bleep Ltd, England'. It looks as if it may have gotten itself twisted inside but not badly. However, it is 'takeapartable' ( always a joy ) so that shouldn't be a problem. I can't imagine a scenario where I would have any use for it so if anyone has a GENUINE use for it you're welcome, for cost of postage. But please, I really don't want to see it on Ebay - I can do that myself! No offence intended. Keep up the postings - it's the best reading I get. |
23rd Aug 2006, 7:03 pm | #2 |
Re: Gizmos.
I think you may find your magnetic cassette tape is , or was a head degausser , one rewinds then plays through to demagnetize the heads, remove without rewind.
Same procedure next time. Doffery |
23rd Aug 2006, 7:24 pm | #3 | |
Re: Gizmos.
Presumably, you're aware how strobes are used, e.g. those on turntables? You need a mains-powered light - fluorescent striplights work particularly well becuase they're flickery. The speed is adjusted until the pattern appears to stay still. If it turns slowly one way or the other, the speed is slightly out. Make sure yours is designed for 50/100Hz operation (as opposed to 60/120Hz USA mains), and check that it's designed to operate at the speed your machines run at. Nick. |
23rd Aug 2006, 9:01 pm | #4 |
Re: Gizmos.
The strobe also needs to be used on the capstan spindle, as this is the part that is speed controlled. I have a Philips "tape strobe", which gives reasonable results.
Jim. |
23rd Aug 2006, 9:23 pm | #5 |
Re: Gizmos.
23rd Aug 2006, 10:12 pm | #6 |
Re: Gizmos.
Is your continuous magnetic tape cassette a NAB cart? I take it you're familiar with these. Type A, the same dimensions but not compatible with an 8-track. Type A runs at 7.5 ips for radio jingles. Type C has a 7 inch spool in it, typically run at 1.75 ips for muzac. Or something else?!?! Graham |
24th Aug 2006, 12:58 pm | #7 | |
Re: Gizmos.
Yes I've used turntable strobes before. My 'workbench' is directly below a mains light so no problem there. The thing is designed as a miniature reel on a handle and the object is to hook it into the tape path manually and observe the strobe. If I could figure out how, I'd include a picture! Definately 50Hz. |
24th Aug 2006, 1:04 pm | #8 |
Re: Gizmos.
Hi. Looks like standard 1/4" magnetic tape to me, in a round plastic canister with central cine slot. Tape exits from a slot and enters through a slot on opposite side. Tried it on a reel/reel machine but couldn't figure out correct route without 'snagging'. Possibly due to the twisted tape I mentioned. Next step I suppose will be to take it apart and try 'untwisting' it. My best guess would be that it would be used for commercial purposes - continuous messaging etc.
24th Aug 2006, 1:05 pm | #9 |
Re: Gizmos.
Sorry for stating the obvious then, Roger.
Presumably, it must be attached to the capstan, or if not, the tape must be threaded around some part of the gadget. I've seen strobe cassettes which seem to work by having a stroboscopic disc which is rotated by virtue of the moving tape being wrapped around it. Have you got a digital picture of it but can't get it to appear here? If so, send me a PM, I'll send you my e-mail address, you can send it to me as an attachment then I can post it here. Nick. |
24th Aug 2006, 1:16 pm | #10 |
Re: Gizmos.
Nick, you have a PM.
Roger. |
24th Aug 2006, 6:35 pm | #11 |
Re: Gizmos.
Sorry Roger,
From your description I assumed it was a "cassette" , however with 1/4 " tape not so. Must be one of the many "endless cassette" type units, as per the Ferrograph or Sony. Cheers. Doffery |
24th Aug 2006, 9:44 pm | #12 | |
Re: Gizmos.
Sorry, I didn't make it very clear - merely quoted the manufacturer's description. If they're that common I guess it's 'bin fodder' then? I have enough clutter around here without adding more. |
24th Aug 2006, 9:47 pm | #13 |
Re: Gizmos.
Pictures from Roger
24th Aug 2006, 10:01 pm | #14 |
Re: Gizmos.
Thanks Nick, for posting the photos for me.
Cheers, Roger. |
24th Aug 2006, 11:58 pm | #15 |
Re: Gizmos.
I had one of these, it came out of an automatic fire alarm which I "recycled" in my teens. Dial pulses on one track followed by the other track playing "Fire, fire fire; this is an automatic alarm reporting from..." all in a calm, somewhat bored monotone. Works the same as the innards of an 8-track cartridge. Tape is pulled out from the middle of the pancake and returns to the outside. I seem to remember the action of the tape being pulled out causes the inner 'spool' with the tape pancake to rotate, causing the tape to be taken up after passing the heads. On the one I had there was a bit of foil over the splice which caused the alarm to stop the tape. ...and don't bin it... if you don't want it I could possibly find a use for it... Regards, Kat. |
26th Aug 2006, 7:10 pm | #16 |
Re: Gizmos.
