Old 3rd Apr 2008, 10:28 pm   #1
paulridgeon
Default Thurlby PL320 circuit or service data
Hello I wonder if anyone can help with a fault I have on a Thurlby pl320 this is a dual power supply.
The unit is quite old brown case but any info would be appreciated.
Fault is one side of the psu is unable to supply any current.
Voltage is present and is adjustable but current limit operates on a tiy ammount of load.
I did find the large 47 ohm power resistor on the pcb was burnt out.
Circuit appreciated.
Many thaks Paul
paulridgeon is offline
Old 4th Apr 2008, 9:43 pm   #2
hysteresis
Default Re: Thurlby PL320 circuit or service data
Hi Paul,
If the burnt out resistor was R8 (please see the attached PCB layout diagram) then that could explain the fault. The output current passes through R8. The resultant voltage drop is used as an input to the current regulator circuit (2nd attached diagram).
The original value of R8 would have been 0.5Ω. Substituting a 0.47Ω wirewound resistor would be fine, as the output current range can be adjusted during calibration.
Just in case you missed the service manual link in the other thread, here it is again:
http://k1.dyndns.org/Vintage/Sinclai...cs%20Products/
John
ID:	16220   Click image for larger version
hysteresis is offline
Old 5th Apr 2008, 8:19 pm   #3
paulridgeon
Thanks very much I really appreciate your help with this.
Thanks
Paul
