Old 21st Jul 2016, 8:26 pm   #1
rockinmark
Default Akai 4000D
I have been given this reel player, the rewind is very slow or stops altogether. It will turn with a little help.
Mark
rockinmark is offline
Old 24th Jul 2016, 11:30 am   #2
akaigxfan
Default Re: Akai 4000D
hello, may be worth checking the rubber idler that does rew, check its condition and that it is clean and dry, also worth roughing up with some fine sand paper. assuming also the drive belt is not slipping or slack.
akaigxfan is offline
Old 26th Jul 2016, 5:54 pm   #3
rockinmark
I have cleaned the wheel rubbers not sure bow to get in side to the motor
If any one can tell me what screws hold it all in the wooden case please
Mark
Old 26th Jul 2016, 9:19 pm   #4
Michael Maurice
Michael Maurice's Avatar
Usually four screws at the back and two screws at the bottom.
BTW the belt only drives the capstan, it has no effect on rewind or FF.
Forum Moderator
Michael Maurice is offline
Old 27th Jul 2016, 12:39 am   #5
camtechman
camtechman's Avatar
On the 4000DS, the back screws also fix the 4 rubber feet in place as well as holding the chassis too.
I hope you don't mind this question, what is your experience & skill level on such machines?
If you are having difficulty with removing the case you may have even greater difficulty in dealing with the more complex mechanism inside that may need dismantling and re-assembly.
When I die, please don't let my Wife sell my collection for the amount I told her I paid for it!
camtechman is offline
Old 28th Jul 2016, 7:53 am   #6
rockinmark
Hi it was just didn't realise the screws for feet hold it in as well I don't have much knowledge but I am willing to learn.
I will photograph every thing first before taking anything apart
Mark
Old 28th Jul 2016, 10:11 am   #7
Nicklyons2
Nicklyons2's Avatar
Another thing; does it play OK and consistently at the correct speed. If the motor capacitor is failing the motor may run but with reduced torque making the rewind problem worse. Play a tape (large spool nearly full) at the beginning and near the end - is it wowing? does it sound like the speed is correct?
Nicklyons2 is offline
Old 28th Jul 2016, 6:52 pm   #8
rockinmark
I have recorded and played a large tape and everything sounds ok. I have played a prerecorded tape that is only 5" spool and that plays good
Mark
