12th May 2023, 10:35 pm | #1 |
Identify an HP item? (Boonton RF Voltmeter)
While googlin' for a picture of a Thorn dropper resistor, I found the interesting History of Thorn, and in there is a picture of the test setup used in 1967, with right in the centre an HP unit I don't recognise. Anyone know?
- Julian It's good here Last edited by Julesomega; 12th May 2023 at 10:53 pm. |
12th May 2023, 10:56 pm | #2 |
Re: Identify an HP item?
Which HP unit do you mean? I can see a Tek 535A/545A/547 scope with a type M 4-channel plugin, a big Advance power supply, some sort of valve voltmeter, another power supply whose manufacturer I can't quite see, and some very in-house looking test equipment.
Chris
12th May 2023, 11:35 pm | #3 |
It looks like "some sort of valve voltmeter"
- Julian It's good here |
13th May 2023, 12:29 am | #4 |
Looks like a Boonton 91D RF voltmeter:
(Image from: https://microscopetelescope.com/prod...decor-mcm-0973) Cheers |
13th May 2023, 2:46 pm | #5 |
Re: Identify an HP item? (Boonton RF Voltmeter)
The Boonton Electronics Corp. (maker of the 91D above) actually had nothing to do with HP, it was Boonton Radio Corp. that HP took over, these are two of six companies making test instruments in Boonton New Jersey.
http://hparchive.com/boonton-nj David |
13th May 2023, 3:03 pm | #6 |
Well done chaps! Nice little unit, I want one (wife slaps wrist)
There are comments about these using a chopper amplifier with 'electrmechanical' choppers
