Old 17th Mar 2023, 1:53 am   #1
rubicon
Default Simple stable triode BFO
I have not seen this before, maybe unique, thort to pass it on.
Developed this to use the triode section of the ECH81 product detector in my Deltahet.
Any triode will work, The .01 anode cap is to isolate the HT from the resonator, they hate voltage gradients. One caveat, the filter will oscillate about 5kC above the nominal, use a 450 kC to get 455, a 455 will resonate at 460. Small freq changes , as in very small can be coaxed by fiddling either resistor values or capacitor values. All the 3 terminal ceramic filters I tried worked similarly.
Output can be taken from anode or grid.
rubicon is offline
Old 17th Mar 2023, 3:59 am   #2
Default Re: Simple stable triode BFO
There were ceramic resonators made specifically for BFO/CIO use. They're fairly stable and a lot more pullable than quartz. Construction/applications articles appeared in the usual radio magazines in the 1980s.
Radio Wrangler is offline
Old 17th Mar 2023, 4:31 am   #3
rubicon
These resonators are designed for use in low Z SS circuitry, never seen them used with valves, but maybe im sheltered. My attempts to find 455kc quartz at reasonable prices failed. To build vacuum state projects is really getting quite difficult now, and does require some innovative thinking....
rubicon is offline
Old 17th Mar 2023, 10:51 am   #4
An impedance transforming network would likely be needed and that would put back in the parts that the ceramic device was replacing. But if letting one modern, out-of-period component in, then you might as well do a transistor BFO.
Old 17th Mar 2023, 11:32 am   #5
rubicon
A TRANSISTOR? Heresy. Using a ceramic filter is bad enough, but a semiconductor?
rubicon is offline
Old 17th Mar 2023, 11:46 am   #6
Jon_G4MDC
Jon_G4MDC's Avatar
Murata CSB430 is only 2 terminal but it's drawn showing 3.
Is it perhaps a ceramic filter of some sort and that is why it is 3 terminal?
Jon_G4MDC is offline
Old 17th Mar 2023, 12:50 pm   #7
trh01uk
trh01uk's Avatar
Looks like it is a filter since the OP said ".All the 3 terminal ceramic filters I tried worked similarly"
Richard
trh01uk is offline
Old 17th Mar 2023, 6:47 pm   #8
Measure capacitance from the signal pins to the (centre) earth pin. Measure C from signal pin to signal pin.
This will sort out whether you have a single resonator with a screen, or whether you have a two-pole filter with commoned ground electrodes.
Transistor technology was quite old by the time ceramic filters came to prominence.
Old 17th Mar 2023, 10:28 pm   #9
rubicon
Yes, these are ceramic FILTERS , most older cheap single chip AM/FM transistor radios use these, the signal enters one side, exits the other, the center pin then grounded. These are marked CSBxxx, CFSxxx, CFUxxx , SFUxxx etc, depending on manufacturer, where xxx is 400, 450, 455, 460, 470, or 500, they all appear to work the same and all oscillate happily as above.
rubicon is offline
Old 17th Mar 2023, 10:37 pm   #10
rubicon
https://www.aliexpress.com/item/3301...d=XdQpF99yzWWr
rubicon is offline
Old 17th Mar 2023, 10:39 pm   #11
rubicon
And, if I read that correct, 50 will cost only a few of your british pounds...
rubicon is offline
