Old 27th Jan 2020, 1:31 pm   #1
Nanozeugma
Nanozeugma's Avatar
Default Black crackle or crinkle finish.
Hi.
I have recently acquired an AVO Test Bridge, the meter movement dates it to 10/47. This one is the second iteration using a 6B8G and no Westector.
It was in pretty decent condition when I received it, and looks even better after a good clean. It appears original inside.
However.
The sheet metal case into which it fits has suffered paint loss in a couple of places which mars the appearance somewhat.
The finish is a tight black crinkle.
Q. Is it still possible to obtain paint to replicate this finish?
Thanks in advance for any insight
ID:	197848   Click image for larger version
Thermionic Emission, warms the cockles of your tubes.
Nanozeugma is offline
Old 27th Jan 2020, 1:42 pm   #2
Default Re: Black crackle or crinkle finish.
It's used on the dashboards of 50s/60s MG cars, and is available from Frost.
https://www.frost.co.uk/vht-black-wrinkle-finish-310ml/
Old 30th Jan 2020, 1:36 pm   #3
Nanozeugma
Nanozeugma's Avatar
Thank you for that, appreciated.
Old 18th Mar 2020, 3:56 am   #4
FrankB
Some of the wrinkle/ crackle finishes I have used here in the U.S. have required "curing" in the oven at 200 deg.F, others do not.
Be sure to check the paint type you buy.
FrankB is offline
