Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Offered and Wanted Messages > Sets, Parts and Service Information Wanted (private buyers only, no swaps)
Sets, Parts and Service Information Wanted (private buyers only, no swaps) If you need help obtaining components, sets or equipment, post a message here. Private buyers only - no traders. No swaps.
Old 19th Feb 2019, 10:54 pm   #1
Nanozeugma
Default 8 mfd low voltage non polarised electrolytic.
As subject. Trying to source a replacement for a reversible 8uF 12v for an FM discriminator. No luck thus far
Thermionic Emission, cures depression, boredom and piles.
Nanozeugma is online now
Old 19th Feb 2019, 11:01 pm   #2
Ed_Dinning
Default Re: 8 mfd low voltage non polarised electrolytic.
Hi if space is not a problem you could use modern low voltage non electrolytic parts, you only need a minimum working voltage part.
I'm surprised that it is a non polar e cap, most use in this position are standard types, but are connected + to chassis.
Ed
Ed_Dinning is online now
Old 19th Feb 2019, 11:14 pm   #3
Argus25
Argus25's Avatar
There are plenty of these on ebay, it doesn't have to be exactly 8uF you can use a couple of 4,7uF 's in parallel or a 10uF, and as long as the voltage is 12V or above its fine, this is one of very many:
https://www.ebay.com/itm/4pcs-NEW-Ni...FxJ:rk:22:pf:0
Argus25 is offline
Old 20th Feb 2019, 2:52 am   #4
Refugee
Refugee's Avatar
I have seen some in a set of filled component drawers I acquired many years ago.
I could put a couple on my tester to see if they are still all right. They were never that reliable.
Refugee is offline
Old 20th Feb 2019, 8:56 pm   #5
Sideband
Sideband's Avatar
Ed
Yes indeed! What radio is it? I've only ever seen normal electrolytics in this position. If it really does have to be reversible, you can connect two normal electrolytic 16uF caps in series, positive to positive or negative to negative.
On Spike Milligan's headstone......I told you I was ill...
Sideband is offline
Old 21st Feb 2019, 5:13 am   #6
Radiocruncher
Radiocruncher's Avatar
RS list some Panasonic 10uf bi polar here https://uk.rs-online.com/web/c/passi...475,4292049494
Would that do?
Regards
Graham
Radiocruncher is offline
Old 21st Feb 2019, 8:08 am   #7
Craig Sawyers
Craig Sawyers's Avatar
10u 16V bipolar for 20p here https://www.hificollective.co.uk/com...chicon_es.html
Craig
Craig Sawyers is offline
Old 21st Feb 2019, 8:35 pm   #8
Steve_Bell
Try Falcon Acoustics or other loudspeaker & crossover suppliers. 8uF is a common value.
Steve_Bell is offline
Old 22nd Feb 2019, 6:25 pm   #9
Nanozeugma
Thanks for all the suggestions people
I got four 10uF 50v for 1.85 posted from a supplier in Devon eventually.
Copyright ©2002 - 2019, Paul Stenning.
