25th Aug 2014, 12:15 pm | #1 |
Unusual resistors?
Can anyone suggest what the figure after the 1 % means on these resistors?
eg: 56 ohm 1% 36; 27k ohm 1% 56; 180k ohm 76 Do these resistors have any particular properties apart from tolerance? Thanks. Ian (Incidentally, how do I type the omega symbol on the forum? [alt 234] doesn't work.) |
25th Aug 2014, 2:06 pm | #2 |
Re: Unusual resistors?
Not unusual, they're quite common in 50's/60's test equipment. Carbon film precision resistors, 1% tolerance. Different makes might be black or pink. They went out of use as metal film and metal oxide types took over.
After coating and capping a ceramic rod, a spiral cut was made in the coating allowing the resistance to be changed, and stopped automatically to get the tight tolerance. Interesting to measure them and see haw far they've drifted. David
25th Aug 2014, 3:21 pm | #3 | |
The original question, is it temperature coefficient? |
25th Aug 2014, 6:06 pm | #4 |
No, tolerance of resistance value at time of manufacture and room temp.
26th Aug 2014, 7:03 pm | #5 |
Hello,
I still don't get what the extra numbers mean! Michael |
26th Aug 2014, 8:18 pm | #6 |
Nor me. The main question posed has been ignored, presumably because nobody knows.
N. |
26th Aug 2014, 8:38 pm | #7 |
Temperature drift rating in parts per million perhaps.
26th Aug 2014, 8:55 pm | #8 |
I would just measure them. I do this with any NOS resistors before using them.
26th Aug 2014, 10:52 pm | #9 |
Several posts moved to a new thread: https://www.vintage-radio.net/forum/...d.php?t=108843
27th Aug 2014, 12:04 am | #10 |
I think those could be series or batch codes. The digits certainly don't correspond directly to common temperature coefficient ranges.
Welwyn used a pinker sort of coating and used to stick their name on everything unless forbidden by contract. I'd go looking for old Philips data first. David
28th Aug 2014, 7:52 pm | #11 |
These certainly look like Philips resistors to me, and the code is a production code. Nothing to be determined from it I fear.
Jac |
31st Aug 2014, 3:18 am | #12 |
Philips seems about right, the triangle rings a bell for that as well. The numbers are most likely batch numbers or encoded date codes.
31st Aug 2014, 6:47 am | #13 |
Paul's advice in post 8 is important. The resistance of many older types of resistor are known to change with time, even without them being used. So, despite being unused and despite the 1% marking, check them before using them.
Philips components were always better than average quality. A lot of information on the technology behind them as well as recommended circuits was printed in 'Philips Technical Review' if I remember the name right. It was distributed to major customers and would make good reading nowadays. The editor was C M Hargreaves, famous for his book on Phillips' Stirling engines. HP has made the HP journal archive available on-line. Does anyone know if Philips has done the same? David
31st Aug 2014, 9:52 am | #14 |
Thanks for all the ideas and thoughts. So it appears the 'odd' numbers may be batch data.
I have measured about half of them (ranging from 330R to 470k) with a meter of claimed 1% accuracy, and as far as I can tell they're all more or less within spec. Ian |
31st Aug 2014, 2:04 pm | #15 |
Then you might want to use them in period equipment for appaerance sake. I wouldn't use them for building anything new because they will be a bit noisier than metal film types.
Might be worth advertising them in small quantities and with the batch numbers declared, because they may have hitherto unsuspected audible properties like the mustard capacitors. David
31st Aug 2014, 3:18 pm | #16 | |
What's the story regarding the mustard capacitors and their audio properties? I always thought they were amongst the 'good guys' in the cast of old-ish capacitors in most of our type of work... Ian |
31st Aug 2014, 4:41 pm | #17 |
David was making a tongue-in-cheek reference to them having become popular with the audio fraternity and the inevitable consequent price inflation...
They are definitely amongst the good guys, very high quality and not prone to going leaky like the contemporaneous paper types. No need for a "replace on sight" policy with those! |
