17th Aug 2014, 5:12 pm | #1 |
Eddystone Variable Cap Seized Up
I have a very nice old (1930s) variable cap from Eddystone. It came out of a homebrew British regen. I have succeeded in getting the old receiver going (with solid state devices vice valves) but today I ran into a strange problem: the tuning cap kind of seized up. Previously it had been completely loose, with the rotors spinning freely. Now, it is very tight -- too tight for the reduction drive. Any idea why this would happen and what I can do?
More info and pictures here" http://soldersmoke.blogspot.com/2011...ech-regen.html Thanks, Bill |
17th Aug 2014, 5:30 pm | #2 |
Re: Eddystone Variable Cap Seized Up
The grease on the bearings has probably dried out and they have jammed, try squirting them with WD40.
Peter |
17th Aug 2014, 8:43 pm | #3 |
Tried that -- it doesn't seem to help. I'm trying to disassemble the cap so as to be able to get at the area where the rotor meets the frame, but no luck.
18th Aug 2014, 7:49 pm | #4 |
Hi Bill, look for broken insulators on the stator or a collapsed bearing. If the bearing was very slack initially one of the balls may be displaced and causing the jam.
Ed |
19th Aug 2014, 12:17 am | #5 |
Ed: I can't seem to get the ball bearing case open.
Bill |
19th Aug 2014, 12:46 am | #6 |
Could you post a picture or two, that might help in the diagnosis.
22nd Aug 2014, 10:56 am | #7 |
Here are some pictures, re my Eddystone cap woes:
25th Aug 2014, 10:43 am | #8 |
A soak in penetrating oil may do the trick, but try a small drop first to make sure it isn't going to damage the brass.
Do I see a grub screw holding the vanes to the shaft? If so removing it may enable the vanes to be pulled off the shaft giving better access to the bearing. Does the shaft nut hold the frame to the bearing. If so it may have been over tightened distorting the bearing. Removing the front circlip may enable the shaft to be GENTLY tapped out of the bearing.
25th Aug 2014, 12:12 pm | #9 |
Is it worth soaking in paraffin?
25th Aug 2014, 12:18 pm | #10 |
Yes, won't do any harm.
25th Aug 2014, 3:15 pm | #11 |
I don't know what the situation is in the USA, but in the UK paraffin (kerosene) is more expensive than petrol. Typically around £7.00 for 4 litres.
So unless you have some paraffin handy, penetrating oil or some other cleaning fluid might be a cheaper option.
