15th Aug 2014, 6:14 pm | #1 |
Microbore copper tube coils
I came upon this homebrew replica '1929 TNT Transmitter' set while searching the web. It uses 1/4" microbore copper tube for, what I assume are, the aerial tuning coil and a reaction coil. What I'm interested to know is:
(1) How would one calculate the number of turns needed for, let's say, a MW coil, or is it simply trial and error? (2) How effective would it be in regards to selectivity and sensitivity? Thanks Nick |
15th Aug 2014, 7:35 pm | #2 |
Re: Microbore copper tube coils
A MW coil in copperbore would be rather large! Think in terms of a hundred turns or thereabouts.
There are various formulae used for calculating inductance of a solenoid, and some appear as 'calculators' on the web. Google is your friend. |
15th Aug 2014, 8:18 pm | #3 |
I'd guess that the circuit in the picture resonates up around 30+Mhz. The MW wave version would look like something that's been removed from a steam engine, or a high-quality liquor still?
B |
15th Aug 2014, 9:06 pm | #4 |
Mmm. The smallest readily available and affordable microbore copper, which would produce a self-supporting coil i.e. no former required, would be about 4mm diameter. A five inch diameter coil is certainly realistic for the breadboard TRF design I have. I will have a look on the web again, but haven't managed to find anything which provides the calculations for anything other than standard wire gauges. If anyone can point me to a calculator which would accommodate the dimensions given herein I would be grateful.
Thanks Nick |
15th Aug 2014, 9:44 pm | #5 |
Ignore the size of the wire/tube a close approximation will be found by using the diameter, turns and spacing using one of the online calculators. The first one on Google http://www.extremeelectronics.co.uk/...?page=isol.php has arbitary 'wire' size too.
Having a bit of fun for 4mm tube spaced 8mm centres it would be 300mm long, 170mm diameter (53 turns) to resonate at 500kHz with a 500pF capacitor, one big coil! Last edited by Guest; 15th Aug 2014 at 9:49 pm. Reason: Had some fun |
15th Aug 2014, 10:53 pm | #6 |
That's one LOUD pantry transmitter- Blenheim Palace?
16th Aug 2014, 12:41 pm | #7 | |
16th Aug 2014, 7:19 pm | #8 |
For that size coil it has to be an 807!!
Ed |
16th Aug 2014, 7:54 pm | #9 |
If a valve is picked on matching the looks, I should be able to hear it up here...
19th Aug 2014, 12:03 pm | #10 |
Yeah, OK.
But if I used 3mm diameter copper wire (SWG 11 gauge) and a 5 inch diameter former, married with a 300pf variable cap, then by Wheeler's formula that would give me a coil of c. 7.5 inches and 63 turns for the whole MW band wouldn't it? Nick |
19th Aug 2014, 12:58 pm | #11 |
Looks about right.
The formula I have always used, which gives a close approximation for inductance of a single layer coil, is: d^2 * n^2 / (18d+20l) where d= coil diameter, n= number of turns, l= coil length, all in inches. 333 uH in your case |
19th Aug 2014, 1:04 pm | #12 |
Cool !
Now I just need to find out where I can buy SWG 11 gauge enamelled or silver-plated wire at an affordable price Nick |
19th Aug 2014, 1:53 pm | #13 |
Don't forget that with bare wire or tube there will need to be some space between each turn, which will increase the overall length of the coil to be used in the calculation.
If you want high Q, spacing at wire diameter may be a good idea, which will nearly double the length. |
19th Aug 2014, 2:36 pm | #14 | |
Nick |
19th Aug 2014, 5:07 pm | #15 |
I would't bother with silver plating at MW frequencies, just polish and varnish to make it look good. 'Compo' brake pipe is cheap and shines up very well.
19th Aug 2014, 7:29 pm | #16 |
