Reply
Old 3rd Nov 2023, 9:34 pm   #3361
G.Castle
Default Re: The Audiophoolery Thread.
Is that a standard silver shorting block, or a high end honey coated, cryogenic treated, non inductive, directional silver shorting block: enquiring minds need to know.
G.Castle is offline   Reply With Quote
Old 3rd Nov 2023, 10:26 pm   #3362
Radio Wrangler
Radio Wrangler's Avatar
Any. Just so long as it's reassuringly overpriced.
Old 3rd Nov 2023, 10:48 pm   #3363
bigfathairyvika
bigfathairyvika's Avatar
Could suggest a useful addition to their directional cables, a series diode to stop signals attempting to go the wrong way.
bigfathairyvika is online now   Reply With Quote
Old 4th Nov 2023, 12:26 am   #3364
fetteler
fetteler's Avatar
Wasn't there some horrid lager brewer that used to try to hoodwink their gullible victims with a similar sales pitch?
Steve.
Those who lack imagination cannot imagine what is lacking...
fetteler is offline   Reply With Quote
Old 4th Nov 2023, 8:55 am   #3365
Craig Sawyers
Craig Sawyers's Avatar
Back to total insanity. How about an ethernet cable costing £3,430.00 for 1metre?
https://www.futureshop.co.uk/nordost...ethernet-cable
Or £25,530.00 for 0.6metres of RCA terminated cables
https://www.futureshop.co.uk/nordost...nnect-rca-pair
Share and enjoy
Craig
Doomed for a certain term to walk the night
Craig Sawyers is offline   Reply With Quote
Old 4th Nov 2023, 9:18 am   #3366
Radio Wrangler
If you've just spent upwards of £100k on some boxes, spending a few quid on some bits of wire to go between them can easily be made to look mismatched
Anyone paying high-end prices is already advertising their gullibility, and there is a whole cottage industry geared up to fulfil their needs.
There's a lot of reassurance in tham thar cable and fuse prices.
Does the ethernet price mean that the cable comes pre-filled with harmonious data?
Old 4th Nov 2023, 9:33 am   #3367
Craig Sawyers
They suggest that they can burn in cables using the Nordost Vidar burn in system.
There are some half way detailed photos on the web of this. It basically generates pseudo random noise using a long repeat length tapped shift register. Then there are various drive circuits for different cables and timers. Cable companies charge for such a burn in of course.
I designed one using tapped shift registers back in the early 80's in my first job, with a repeat length measured in decades. For an industrial application. Fed into a D-A to give real noise-like signals.
And more recently a noise generator based on avalanche in a pn junction, converted to pink noise and then a power amp to test loudspeakers to near destruction. By measuring the current you can work out the coil temperature.
Craig
Old 4th Nov 2023, 9:37 am   #3368
Craig Sawyers
And because Wikipedia is your friend - tapped shift register noise generation
https://en.wikipedia.org/wiki/Linear...shift_register
Craig
Old 4th Nov 2023, 10:43 am   #3369
mark_in_manc
Share and enjoy
Craig
I don't have any ethernet cable at home, but I do have quite a lot of random x-to-y cables including phono cables. Since I believe they work as well as the ones on display here, I'm going to have a little look around later this morning, count up how many I can find, multiply the number by £25k and rejoice at all the money I have saved. I suspect it will be more than my total net worth (including the house)
(Previously I rejoiced at selling some B&K jack plugs at about £10 a pop as part of my charity sell-up, but I see now I was woefully unambitious!)
"The best dBs, come in 3s" - Woody Brown
mark_in_manc is online now   Reply With Quote
Old 4th Nov 2023, 11:39 am   #3370
emeritus
As far as I know, the only type of electric cables that benefit from burning-in, are ones used for high voltage power transmission, especially coaxial ones for HVDC. The voltage is slowly ramped up to maximum in one direction, then slowly ramped down and then ramped up to maximum in the opposite direction, then ramped down again and so on for a number of cycles. This is done to relieve any dielectric strain in the insulation that could lead to insulation breakdown.
emeritus is offline   Reply With Quote
Old 4th Nov 2023, 1:18 pm   #3371
Malcolm G6ANZ
Malcolm G6ANZ's Avatar
So if I was to make up some phono to phono leads and advertise them as 'similar' to the Nordost cables and make no claims as to their sonic improvement could I make a killing?
Malcolm G6ANZ is offline   Reply With Quote
Old 4th Nov 2023, 3:49 pm   #3372
Beobloke
The last time I did a major re-wire on some loudspeakers, the wire I used had been burned in for several years at 240Vac with varying loads of a random nature.
Obviously it sounds much less audiophile when I explain that this was because the wires used were the 2.5mm cores of our old garden mains extension lead, but still…
Beobloke is offline   Reply With Quote
Old 4th Nov 2023, 6:41 pm   #3373
barrymagrec
Presumably you flushed out the 50Hz hum before using it?
barrymagrec is offline   Reply With Quote
Old 4th Nov 2023, 7:30 pm   #3374
Radio Wrangler
"Shift Register Sequences" By Solomon W Golomb (pronounced 'Gollum')
Is the tome on creating maximal length sequences with analyses via modulo-2 arithmetic.
Old 4th Nov 2023, 8:15 pm   #3375
mark_in_manc
We used to use something called MLSSA years ago, for measuring electro-acoustic transfer functions - the deterministic (but random-like) 'out' signal could be deconvolved from the return signal to give a complex transfer function. It amazed me how the spectrum of the one-shorter-than-a-power-of-two MLS was entirely flat, but if you added a one or a zero on the end to give a nice round 1024 point sample length (for example) that was no longer true at all. At least that's how I remember it. I'm glad I don't need to know why that is any more!
Old 4th Nov 2023, 10:38 pm   #3376
Radio Wrangler
There was also stuff about how to use multiple bits to feed a DAC and to wind up with a close approximation to Gaussian white noise.... and at the very end were the masters' final exams... some of us had no choice but to go for full immersion. It left nightmares! doing bit by bit arithmetic and throwing away all the carries just seemed so wasteful.
From a point of having used it, our data error test sets used PRBS maximal length sequences as laid down by CCITT so that wasn't a problem. The receiver shift register was just forcibly flushed with current data and then looped with the feedback path once full so it could run independently as a comparison for later incoming data so errors could be counted. The flaw is that if the error rate is too high, the chances of an error corrupting the synchronisation brings the whole house of cards down.
The user knows that things are bad, but not just how bad.
Old 9th Nov 2023, 2:08 pm   #3377
LPsmash
LPsmash's Avatar
£695 Graham Slee Phono Stage.
Vid shows the owner installing Audio Note Caps!
By all means I'm no engineer. But I still sense total delusional BS!
https://www.youtube.com/watch?v=hapvEH819kE&t=1s
S.
LPsmash is offline   Reply With Quote
Old 9th Nov 2023, 2:46 pm   #3378
Ted Kendall
Never mind the tweaks - £695 for that?. Two op-amps and some bits?
Ted Kendall is offline   Reply With Quote
Old 9th Nov 2023, 3:02 pm   #3379
LPsmash
LPsmash's Avatar
Yup.
S.
Old 9th Nov 2023, 3:49 pm   #3380
knobtwiddler
Multi-layer PCBs are cheap as chips now. It is using a PCB that looks identical to the one in the 1973 scope that I have been servicing today. A phono preamp is a basic piece of electronics and the self-noise of the typical MM cart means that ciruitry improvements are likely buried under the cart's own resistive noise, but for £700 it ought to have dedicated power / ground / L / R signal planes, if even just for show.
knobtwiddler is offline   Reply With Quote
Reply
