Old 19th Apr 2018, 4:59 pm   #21
TonyDuell
Default Re: Teppaz 3310 More car booting....
I do love French engineering (and no, I am not being sarcastic). They often seem to have very ingenious designs.
TonyDuell is offline
Old 19th Apr 2018, 5:36 pm   #22
Hartley118
Hartley118's Avatar
I think that a visit to France should be mandatory in every engineer's education, if only to realise that there's always a different way of solving a design problem!
Martin
BVWS Member
Hartley118 is online now
Old 19th Apr 2018, 6:58 pm   #23
Wishiknewmore
I hope that I have the turntable sorted, thank everybody, my concern now is the cartridge /stylus, the cartridge that came with the set fits, but it looks like it is "notched" to rest in a particular position and I would assume that this would be so that the stylus was perpendicular to the record, this one seems to be exactly 90 degrees out. (see picture)
The options seem to beits either wrong cartridge for this set or the notched mount at the end of the arm has been turned?
It does look like someone has had a go at turning the notched mount either successfully, with the wrong result or just chewed it slightly and failed possibly meaning that the cartridge does not belong to this set
The notched end looks as if its plated brass pressed into the cast (white metal) arm, which I am not keen on trying to move!
Suggestions?
Philip
ID:	161387   Click image for larger version
ID:	161388   Click image for larger version
Wishiknewmore is online now
Old 19th Apr 2018, 7:48 pm   #24
mark_in_manc
I can't see what on the cart engages with that slot. I can see why you don't want to try to turn it and wring the end of the arm off. If all else fails, perhaps you could cut another slot at 90 deg to the existing one...but too early perhaps for drastic action just yet!
mark_in_manc is offline
