Old 14th Apr 2018, 7:58 pm   #1
PsychMan
PsychMan's Avatar
Default Bush SRG86 Speakers - Repair or replace?
What has befallen them! As attached see the state of the speakers in my Bush SRG86 radiogram.
Unfortunately, like the muppet I can be, I hadnt inspected the speakers in this radiogram until I'd spent considerable time renovating the chassis and was about to reinstall it hoping for great audio, as I'd already enjoyed on my workshop test speakers.
Its in poor condition this radiogram, so really I should have checked, I think somebody rescued it dumped in the street many years ago. Is this mice damage? There were lots of chunks of speaker cone sitting in front of them which would suggest that to me.
I've never had such bad speakers to deal with. I don't want to spend zillions having them re-coned, and not sure how difficult it might be for me to have a go? If you were in my shoes would you source modern (less efficient) replacements? Contemporary replacements, or get them reconed?
One tweeter miraculously was untouched by possible rodents, but that's not much consolation
ID:	161111   Click image for larger version
PsychMan is offline
Old 14th Apr 2018, 8:18 pm   #2
mark_in_manc
Default Re: Bush SRG86 Speakers - Repair or replace?
Wow!
What size are the units? I'm sure people will have something useable - I may have some small ones, for a start.
mark_in_manc is offline
Old 14th Apr 2018, 8:48 pm   #3
kirstyd
what ohms are they .I have two 10 inch speaker from a more modern transistorised Bush radiogram here .You can have them if you pay the postage
kirstyd is offline
Old 14th Apr 2018, 9:05 pm   #4
kirstyd
just put a meter on them .they appear to be around 4 ohms .The two brown ones are only 8 inch and 3 ohms they came from a Cossor radiogram
ID:	161113   Click image for larger version
ID:	161114   Click image for larger version
ID:	161115   Click image for larger version
kirstyd is offline
Old 14th Apr 2018, 9:29 pm   #5
Edward Huggins
How sad. I would definately go for the 2 Plessey 8" units on offer. Regrading the tweeters, you can get two new 3" coned units, but they are liable to be 8 ohms. Use new 2.2 uf caps for their filters.
Edward.
Edward Huggins is offline
Old 14th Apr 2018, 9:35 pm   #6
PsychMan
PsychMan's Avatar
The main speakers are 10 inch and the tweeters 4 inch, I’ll check the ohms ratings tomorrow. Thanks for the kind offers, I may well take you up on them if they match well. The remains of these are celestion
PsychMan is offline
Old 14th Apr 2018, 9:59 pm   #7
mark_in_manc
Sorry - I didn't think my small ones sold at Golbourne, but I can't find them anywhere so perhaps they did! I'll have another look tomorrow.
Old 14th Apr 2018, 10:01 pm   #8
paulsherwin
paulsherwin's Avatar
If they measure 4 ohms DC then they are likely to be about 6 ohms impedance, so 4 ohm or 8 ohm will probably be OK. Car stereo speakers make good replacements for this sort of application, and are mostly 4 ohms. The boy racer style bass speakers found in customised cars are often 10”, and standard speakers are often 4" with a whizzer cone. A visit to your local scrappie or dismantler may yield lots of possibilities for not much money, and they may even sound better than the originals.
paulsherwin is online now
Old 15th Apr 2018, 1:26 pm   #9
PsychMan
PsychMan's Avatar
That’s a nice idea Paul, plenty of “mid-sub” speakers and 4 inch full range speakers about, with a slight change to the crossover caps I might get some great results.
Kirsty do you remember which model of radiogram your speakers came from?
PsychMan is offline
Old 15th Apr 2018, 2:08 pm   #10
Edward Huggins
You can't really mount 4" full range HiFi type speakers in the Radiogram's cabinet as these units really need to be in properly sealed or ported enclusures.
You'll not improve on fitting the two 10" units (sorry, I originally thought the baffle apertures were for 8" units) in your Bush which is how it was designed to operate. Get it going, you can always add the tweeters later.
Edward.
Old 15th Apr 2018, 6:01 pm   #11
PsychMan
PsychMan's Avatar
I see what your saying Edward RE: less than ideal cabinet for hifi speakers, but as these are car speakers a car door provides a pretty poor cabinet for speakers and a cars interior a poor environment for sound itself so I'd expect these to be pretty forgiving.
I may go either way at this point
PsychMan is offline
Old 15th Apr 2018, 6:48 pm   #12
PsychMan
PsychMan's Avatar
10 inch speakers reading 4.6 ohms, sticker on them says "5 ohm +"
The 4 inch speakers read 2.6 ohms, no markings
PsychMan is offline
Old 15th Apr 2018, 7:00 pm   #13
simpsons
Of all the shortcommings of a domestic radiogram, the loudspeaker is 2nd to the top after stereo separation.
Whilst I don't have experience of the units Bush fitted to the SRG 86, because the main speakers are mounted at almost floor level and quoted 10" in diameter, you will need the tweeter to reproduce anything over 4Khz so you can hear the highs standing or seated and the 5uF in series with the tweeter suggests the designer thought the same.
The design of the radiogram is in my opinion quite elegant what a pity the cabinet isn't in as new condition however it is necessary to source resonably efficient loudspeakers designed to work on an open baffle.
Go for the 10" ones on offer plus 4" tweeters, you can adjust the value of the tweeter capacitor if you are really critical about the sound but, remember, it is not a high quality system with pretty flat resonse from 50Hz to 22Khz, it's a radiogram.
Chris
simpsons is offline
Old 15th Apr 2018, 7:26 pm   #14
kirstyd
I used to have one of these radiograms [the stereo version ]now whilst its not HI Fi the sound quality from it was excellent .And it was the top of the range offering from bush in 1958
ID:	161162   Click image for larger version
kirstyd is offline
Old 17th Apr 2018, 7:37 am   #15
PsychMan
PsychMan's Avatar
Have sent a PM to Kirsty for further info on her kind offer. I think I’ve found some identical tweeters, and have posted in the wanted section just in case anybody has the same 10’’ drivers, very unlikely but worth a go.
PsychMan is offline
Old 17th Apr 2018, 12:10 pm   #16
Nickthedentist
Nickthedentist's Avatar
These radiograms seem to crop up frequently on eBay so maybe your only way of getting original drivers would be to buy one to split for parts, or looks out for one that's already been "parted-out" - you often see radiogram chassis/speakers/autochanger without cabinet for sale.
Alternatively, if there's space, you could semi-temporarily install a pair of hifi speakers c/w their cabinets inside the radiogram. A pair with large drivers and tatty cabinets (e.g. 1970s Wharfedales) could be had for peanuts. Many have a nominal impedance of about 6R and it would be very easy to experiment.
Nickthedentist is online now
Old 17th Apr 2018, 12:18 pm   #17
paulsherwin
You could also make a pair of baffles allowing you to fit 8" drivers, which are much easier to find in scrap hifi speakers and car systems.
Old 17th Apr 2018, 1:56 pm   #18
PsychMan
PsychMan's Avatar
Ive put a wanted thread here with some more pictures just in case somebody has some https://www.vintage-radio.net/forum/...d.php?t=145758
As Chris says they seem like they were great speakers at one point so keen to get something decent. Id rather not try different sizes so perhaps I'll get whatever works for now and have a think. I have asked a local firm for a quote on re-coning these, but not hopeful it will be affordable. There is also a chap selling some near identical ones on eBay but asking £200 the pair!! Fair play if he ever gets that for them
PsychMan is offline
Old 17th Apr 2018, 6:05 pm   #19
Leon Crampin
The Murphy A272C appears to use a very similar 10" Celestion unit. I don't have a spare, but someone may be scrapping one of these sets.
Leon.
Leon Crampin is online now
Old 17th Apr 2018, 6:31 pm   #20
PsychMan
PsychMan's Avatar
Thanks Leon, always good to know. I think I'm going to accept Kirstyd's kind offer for now in lieu of finding some correct replacements, and if happy with the sound I may just keep them permanently.
I've found some tweeters that look identical on ebay, so hopefully I can retain the 1 undamaged tweeter for some originality
PsychMan is offline
