26th Aug 2022, 2:01 pm | #1 |
Ferguson Fieldfare 348BT
This is the Fieldfare MK1 from 1959, I believe this was Fergusons first venture into Transistorised radios. It is complete with the fragile perspex handle. It takes two 6v batteries. I put 2 batteries in and was rewarded with a working but low volume radio. Tested battery consumption 10ma in red lead, 0ma in black lead. Checked the double pole switch, it was OC after working the switch for a while I got a circuit. But still no volume, the battery not drawing any current. Checked the OP TX it has six contacts 3 on each side, circuit shows one primary winding and 2 separate secondary windings. Turns out one of the secondary contacts terminates on the primary side and all windings tested ok. I eventually found the power was not reaching the PCB. I thought maybe a crack in the run of wire, not un-heard of but rare. When I touched the black wire where it contacted the switch it fell off, it had been held on by the insulation that was melted into the solder. I suspect when stripped 63years ago the wire was damaged and when it eventually failed the set put into storage.
Pleased I did not dive in and change all the Caps. Only thing needed was the Black wire stripping back and soldering, (pic 3). It now works well drawing in a lot of stations. John.
My favourite text message "I'll be there in five minutes, if not read again" Last edited by 60 oldjohn; 26th Aug 2022 at 2:18 pm. |
26th Aug 2022, 3:49 pm | #2 |
Re: Ferguson Fieldfare 348BT
What a neat looking little radio ; there's clearly been some effort put into styling the case rather than the usual way of building the insides then getting someone to make a box to put them in. Did Ferguson employ a recognised industrial design person to do their cases in the same way as Bush did with Tom Karen and Ogle Design??
Also fascinating to see it uses a single transformer push pull output stage, that was rather leading edge for 1959!!
26th Aug 2022, 4:22 pm | #3 |
I am trying to make one good set out of two of these unfortunately now on hold as I empty the flat.
If the speaker fails its hard to sub the speaker that bolt coming out the back is part of the fixing that holds the two halves of the case together. Both chassis work OK although one has very bad corrosion on all the metalwork but has the better case which seems to be like a moulded chipboard covered with a mucky brown vinyl material. One speaker is a sub so no way to close up the case Cheers Mike T
26th Aug 2022, 6:27 pm | #4 | |
When I unscrewed the back and lifted it It was that heavy that I thought the circuit was attached to the back, but no it was just real thick wood 5/8" or 15mm this is to allow for the shaping of the case. John.
My favourite text message "I'll be there in five minutes, if not read again" |
26th Aug 2022, 6:39 pm | #5 | |
Hi Mike, I agree 30R speaker with a bolt, would take some finding. If you have a spare escutcheon I'm looking to buy one. The bolt has damage that area on my set. I hope you have a good handle they look very fragile. Cheers, John.
26th Aug 2022, 6:42 pm | #6 |
I will see what I can do
Cheers Mike T
26th Aug 2022, 6:45 pm | #7 |
27th Aug 2022, 10:40 am | #8 |
Yes Oldjohn, a very fine constructed Ferguson radio. 20m/a battery consumption at average listening level and 400mw output.
This one came off the tip a very long time ago and has never been tested. Your thread stimulated some action! A switch clean brought forth music and very good reception. Now where can I get a pair of 6V PP1s at 3/3d [16P] each? I think we have totally lost the plot as we have with so many things with portable radios. John. |
27th Aug 2022, 2:23 pm | #9 | |
John.
27th Aug 2022, 3:18 pm | #10 | |
John.
27th Aug 2022, 3:23 pm | #11 | |
Paul |
27th Aug 2022, 3:23 pm | #12 |
I'm sure my knobs looked pretty much the same.
The bright doesn't seat well I assumed because the knob had shrunk a bit. Unfortunately mine are not to hand. Cheers Mike T
27th Aug 2022, 3:51 pm | #13 |
Thank you for the photos, I have deleted the original request, as I realised it was a Fidelity Ayr that I had on the bench yesterday, not the Ferguson, The knobs are very similar. The "Ayr and Ferguson. My Ayr knobs had a gap maybe a mm or so all the way around the bright which I think may be wrong. Anyone able to comment?
John.
27th Aug 2022, 8:35 pm | #14 |
If anyone has one of these being broken, I need various parts to complete/tidy mine.
Thanks |
28th Aug 2022, 10:32 am | #15 |
A better front view of the 348BT. I wasn't aware of the weak handle problem. I won't use it again!
I have left it unmolested with just a wipe over. The bright parts could be polished up but that may take away some of it's peaceful aging. John. |
28th Aug 2022, 11:52 am | #16 | |
Yours looks in good condition. Mine had a loose grill, it was missing the press on steel clip. Quickly remedied with a spare clip. I am having an interesting time picking the 1950 / early 60s sets of the pile and getting them working, most cases little or nothing wrong, they just seem to keep working. John.
My favourite text message "I'll be there in five minutes, if not read again" Last edited by 60 oldjohn; 28th Aug 2022 at 11:57 am. |
28th Aug 2022, 12:56 pm | #17 |
The handle would be vulnerable to impact, but I can't imagine it giving way under the weight of the set, so I've always carried mine around by theirs. I say "theirs" because, as I've only just noticed, the handle of the late Fawn valve portable, 343BU, is very much the same as that of the Fieldfare. The perspex sections seem to differ only in the model name they carry, and the wire ends are of the same length but bent at different points because the Fawn is a smaller radio.
Paul |
28th Aug 2022, 6:46 pm | #18 |
Looks good! I restored mine last year - came up lovely after a careful scrub and a clean/ polish of the speaker fret and badge - I've had it for some time and used to run it off 2 x 6 volt rechargeable batteries - I changed that to C cells this time. It works very well - it needed more of a clean and fettle than any electronic work. It now sits on my kitchen window with an Alba transistor and a Pye P75 - love listening to Test Match special on it!
Cheers Andy |
29th Aug 2022, 12:54 pm | #19 | |
The "Designed by....." tag was often a feature of many Manufacturer's Marketing. The days of getting someone in the Drawing Office to do it were long gone!
Edward. |
