6th Apr 2015, 12:29 pm | #1 |
Tesla 308U capacitor
What type of capacitor should I use to replace the circled one in the attached image?
Thanks Peter |
6th Apr 2015, 1:13 pm | #2 |
Re: Tesla 308U capacitor
In that position, across the rectifier, a high-voltage ceramic.
6th Apr 2015, 10:17 pm | #3 |
Thanks AJS
I can get 2KV rating. Is that over the top? P |
9th Apr 2015, 2:33 pm | #4 |
It will work, but it won't need to be rated 2kV. The most that capacitor is ever going to see under fault conditions is the peak-to-peak voltage of the supply, or about 3 times its RMS value.
10th Apr 2015, 10:14 am | #5 |
Thanks for clarifying that, AJS.
P |
10th Apr 2015, 3:14 pm | #6 |
Instead of a 2kV (or whatever) DC rating, should it be a Y-rated AC cap? The original won't have been, but the replacement could be. That way you get fail-safe operation.
10th Apr 2015, 5:11 pm | #7 |
Since its failure isn't a safety issue, an X cap would be adequate. Its galvanic connection is between line and neutral rather than line and ground/accessible metal.
10th Apr 2015, 6:34 pm | #8 |
It's not a safety-critical part, so it doesn't need the Y rating. It's just providing some RF suppression.
Interesting, because I always thought of diode switching noise as a problem only with fast semiconductors.
10th Apr 2015, 8:51 pm | #9 |
I expect that it's there to prevent modulation hum as much as anything, as a set with "AC/DC" power supply arrangements won't have the incoming (power lead) RF isolation of a set with classical primary/secondary screening in its mains transformer.
"Y" rating might not be necessary- but 4n7 Y ceramics are widely available and inexpensive and, as well as purely mains voltage considerations, will have kV-amplitude spikes taken into consideration at design. The thickness of ceramic between the faces does inspire confidence. |
