1st Feb 2016, 12:12 pm | #1 |
Avo Wide Range Signal Generator 'Force' socket
This model has a high level output available at a special socket marked "Force". Does anyone have a picture of the special plug that fits into the socket? The socket itself is around 1/8" diameter and sits about 4" deep at the bottom of a tube.
Also, I would appreciate a picture of the wire stand originally fitted to the rear of the case. It's missing from my example, and I'd like to make a replacement to enable the generator to stand on the bench. Thanks in advance, Phil
1st Feb 2016, 7:32 pm | #2 |
Re: Avo Wide Range Signal Generator 'Force' socket
Have you tried the car aerial type of plug?
2nd Feb 2016, 11:13 am | #3 |
Thanks, and I can understand why you've suggested that as it looks superficially similar, but in fact the car aerial plug is not suitable as the socket tube is much too deep and rather larger in diameter.
Never mind though, in the meantime using a bit of ingenuity I have come up with the arrangement shown on the attached pictures which actually works very well. Phil
