Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Offered and Wanted Messages > Sets, Parts and Service Information Offered (private sellers only, exact price required, no swaps)
Sets, Parts and Service Information Offered (private sellers only, exact price required, no swaps) You may announce components or sets for sale or offered free here. Private collectors only - no traders. You must include an exact price. No swaps.
Old 26th Feb 2024, 10:47 pm   #1
whiskas
whiskas's Avatar
Default More surplus items! Components, Tapes, etc - Have a look!
Hi All,
More stuff to go, all good quality items, reasonably priced as always.
Postage:
£2 - £2.50 (large letter items)
£4.00 for packet sized items
You know the drill chaps, I combine post, etc.
Please leave anote in the thread and send a PM with your requests.
No hat.
1. 15x Mullard/Philips 680uf 10V 108 Series long life capacitors.
Measure excellent, great quality.
£4 (or 3 lots for £10) +post (6 lots available)
2. Lot of mixed heatsink washers, TO3, TO-220 TO126 etc.
Handy to have when building and repairing!
£2 + post
3. 4x push grip Grounding terminals, panel mount.
£2 + post
4. 5x RS 2N3819 classic FET transistors.
Quality New Old stock originals!
£3 + post
5. RS ZN1034E New old stock Precision timer/counter IC's
Hard to find now!
£3 each + post
Name:	mu 680uf 10v.jpg
ID:	293689   Click image for larger version
ID:	293690   Click image for larger version
ID:	293691   Click image for larger version
ID:	293692   Click image for larger version
...where on earth did that spring/screw go??
whiskas is offline   Reply With Quote
Old 26th Feb 2024, 10:49 pm   #2
whiskas
whiskas's Avatar
Default Re: More surplus items! Components, Tapes, etc - Have a look!
6. Selection of NOS Zener diodes, very useful voltages 5V1, 5V6 12V 15V. Quality New Old stock items. (packs on left have 4 diodes each, sealed packs on right have 5 each)
£3 + post
7. Set of 6 mini 'Dremel' type cutting/shaping tools for miniature work. Sealed in pack
£4 + post
8. 100x BZX85C 7V5 1.3W Zener diodes, NOS.
£3 + post (2 lots available)
9. 20x SRC 150pf silver mica caps. 200V working.
New old stock
£3 + post
10. 13pcs Wima 0.22uf 100V MKS2 5mm pitch polyester caps
£2 + post
ID:	293694   Click image for larger version
ID:	293695   Click image for larger version
ID:	293696   Click image for larger version
ID:	293697   Click image for larger version
Old 26th Feb 2024, 10:51 pm   #3
whiskas
whiskas's Avatar
11. 10x RS 100pf 160V polystyrene capacitors in sealed RS pack. Interestingly, this pack has the wrong insert in it! (Says 10uf electrolytic caps!)
£2 + post
12. 32pcs ITT 0.1uf 100V polyester capacitors. Ex equipment. all good, fine to re-use.
£3 + post
13. Mullard C280 0.022 & 0.033 caps in 'Seme' packs.
(14x 0.033uf & 9x 0.022uf).
£2 + post
14. 20x Philips 3300pf 160V 1% polystyrene caps.
Extended foil design, the best!
£3 + post
15. RS multiturn pot, 1K ohm. Very high quality, suits test gear etc.
£3 + post
ID:	293699   Click image for larger version
ID:	293700   Click image for larger version
ID:	293701   Click image for larger version
ID:	293702   Click image for larger version
Old 26th Feb 2024, 10:52 pm   #4
whiskas
whiskas's Avatar
16. 4x 1960's Belling Lee 1.25" Fuseholders, panel mount.
Used, but good, sound condition.
£4 + post
17. SONY Headphone amplifier module. High quality, based on the Mitsubishi M5218 IC which is very effective for driving a wide range of headphone types. Came out ofd posh CD player that was 'retired'.
£5 + post
18. 4x NEW RS switches, 3x Push to make, 1x SPDT toggle.
Really nice 1970's items !
£3 + post
19. 2x RS 6.8mH 2A Suppression chokes, new in pack.
£3 + post
20. 7x New Sony 3.5" HD floppy discs, never used
Reliable as far as floppies go!
£3 + post
ID:	293704   Click image for larger version
ID:	293705   Click image for larger version
ID:	293706   Click image for larger version
ID:	293707   Click image for larger version
Old 26th Feb 2024, 10:53 pm   #5
whiskas
whiskas's Avatar
21. Mitsumi Tape head set. (Ex martantz tape deck)
Very good condition, complete with Erase head too. Wiring complete with headers attached, (check pinout)
£4 + post
22. Aerial base for transmitter? Heavy, with a good run of RG58 cable
£3 + post
23. Valve screening cans, all in good condition. B9A and B7G types
£3 + post
24. Ice cream tub of mixed components I dont have time to sort out.. resistors, caps switches etc etc
£4 +post, have a rummage!
25. 11x Vintage used cassette tapes, including a few SONY & a BASF chrome, and one TDK metal tape!
Totally untested, but very clean and tidy overall.
£5 + post
ID:	293709   Click image for larger version
ID:	293710   Click image for larger version
ID:	293711   Click image for larger version
ID:	293712   Click image for larger version
Old 26th Feb 2024, 10:54 pm   #6
whiskas
whiskas's Avatar
26. Lot of 100R (mostly) power resistors. Mostly new
£2 + post
27. 10x 10K 78W power resistors, New Old stock
£2 + post
28. 2x RS LM317K, one new, one good pull with full leads.
£2 + post
29. 3. 8x United Chemi-con 50uF 30V @ 125C, ultra reliable caps with Teflon end seals! These are the business for valve cathode bypass, etc.
£4 + post ( 2 lots available)
30. 30x Mullard 22nf (0.022uf) Cermaic capacitors. Very popular handy value. Quality parts.
£3 + post
** END OF ITEMS **
ID:	293714   Click image for larger version
ID:	293715   Click image for larger version
ID:	293716   Click image for larger version
ID:	293717   Click image for larger version
Old 26th Feb 2024, 11:03 pm   #7
ben
ben's Avatar
Could I have numbers 21 (tape heads), 24 (box of components) and 25 (cassettes), please?
Ben.
Old 26th Feb 2024, 11:33 pm   #8
Philips210
Hi Rob.
Can I put my name down for one of the ZN1034Es (item #5) and the switches (item #18) please?
Symon
Philips210 is offline   Reply With Quote
Old 27th Feb 2024, 12:30 am   #9
ScottBouch
ScottBouch's Avatar
Yes please to item 3, the grounding terminals. I have a piece of equipment with broken terminals of the same type!
Thanks, Scott
www.scottbouch.com
ScottBouch is online now   Reply With Quote
Old 27th Feb 2024, 7:24 am   #10
Keith956
Keith956's Avatar
Hi Rob,
I'd be interested in numbers 4 and 11 please,
thanks,
Keith
Keith956 is offline   Reply With Quote
Old 27th Feb 2024, 9:39 am   #11
DMcMahon
DMcMahon's Avatar
Rob, I would like items 7 (Dremel type cutting tools) and 17 (headphone amp), will P.M.
DMcMahon is offline   Reply With Quote
Old 29th Feb 2024, 12:16 am   #12
whiskas
whiskas's Avatar
Update, some have items sold
- The following items are still available:
1. 15x Mullard/Philips 680uf 10V 108 Series long life capacitors. Measure excellent, great quality.
£2 + post
Hard to find now! **One left**
£3 each + post
£3 + post
New old stock
£3 + post
£2 + post
£3 + post
£2 + post
£3 + post
£3 + post
£4 + post
£3 + post
£3 + post
£3 + post
£3 + post
£2 + post
27. 10x 10K 7W power resistors, New Old stock
£2 + post
£2 + post
£3 + post
Old 29th Feb 2024, 9:00 am   #13
Aub
Aub's Avatar
Could I have items 2, 6 and 9 please Rob?
Thanks
Aub
Life's a long song, but the tune ends too soon for us all.
Aub is offline   Reply With Quote
Old 29th Feb 2024, 2:45 pm   #14
greg_simons
greg_simons's Avatar
Item two, the washers, could definitely use them.
Greg.
Picture, sound?, DOOR.
greg_simons is offline   Reply With Quote
Old 29th Feb 2024, 4:13 pm   #15
whiskas
whiskas's Avatar
Sorry Greg, Aub just clinched those…
I like your profile icon, having a fondness for Japan myself
Old 29th Feb 2024, 5:12 pm   #16
greg_simons
No problems, cheers.
Greg.
Old 2nd Mar 2024, 12:10 pm   #17
yestertech
yestertech's Avatar
Item 29 for me please
Andy
yestertech is offline   Reply With Quote
Old 6th Mar 2024, 10:04 pm   #18
BenHoper
Items 12,13,16, 29. Please. I’ve just replied on your valve thread too.
BenHoper is offline   Reply With Quote
Old 7th Mar 2024, 10:03 am   #19
gezza123
gezza123's Avatar
can I have item No. 15 pot please.
and how to I post have no paypal
thank you gezza123
gezza123 is offline   Reply With Quote
Old 8th Mar 2024, 1:34 am   #20
whiskas
whiskas's Avatar
Hi Gezza, I can't send you a PM as it says you have chosen not to receive Private messages when I try to send one....
