Old 17th May 2021, 5:39 pm   #1
robot797
Default Mullard E7600/3 (Adapter 10A info needed).
Hello.
I wanted to use my tester to test a few PL504's today but I can't test them without a 10A adapter. It was supposed to be listed in the E7600 MK4 manual but I can't seem to find it.
Who can help me find a clear drawing of one?
Thanks.
robot797 is offline
Old 17th May 2021, 6:52 pm   #2
chriswood1900
Default Re: Mullard E7600/3 (adapter info needed)
See post #135 in this thread by Ed.
https://www.vintage-radio.net/forum/....php?p=1223253
Originally Posted by Ed_Dinning View Post
Hi Folks, attached details of the 10A and 13 adaptors.
From my notes there are references to a 10, 10B, 11 and 12 adaptors, but perhaps these were for early TV tubes before the special adaptors were produced
Note that some adaptors have a male top cap attached. This is usually for boost diodes where the TC is cathode.
Ed
He has drawn it out.
Chris Wood
BVWS Member
chriswood1900 is offline
Old 17th May 2021, 7:38 pm   #3
robot797
Yes I saw it but somehow I don't understand it.
robot797 is offline
Old 18th May 2021, 4:25 am   #4
robot797
OK. I tried all combinations for only the filament and I did not get any result. I don't know what way to count the pin numbers on the B9D socket.
So filament is connected to either 3-6 or 6-7?
I need more help please.
robot797 is offline
Old 18th May 2021, 9:24 am   #5
Station X
Station X's Avatar
Please confine this discussion to this thread.
Graham. Forum Moderator
Station X is online now
Old 18th May 2021, 11:22 am   #6
chriswood1900
On a PL504 the heater pins are 4 & 5 looking at the base and counting clockwise, Pin 1 is the first one after the gap.
You could try measuring the resistance to check the filament/heater pins 4&5 which will be around 13 to 14 Ohms when cold and help you identify them.
This might help you understand the valve.
http://www.r-type.org/exhib/aaq0265.htm
Chris Wood
BVWS Member
Old 18th May 2021, 2:32 pm   #7
robot797
I know that, but I was talking about the little circuit placed in this thread
robot797 is offline
Old 18th May 2021, 3:04 pm   #8
Station X
Station X's Avatar
The circuit shows adaptors ie a male plug, which plugs into the tester, and a female socket which the valve being tested plugs into.
The wiring between plug and socket isn't necessarily straight and a wire to a top cap is included.
Old 18th May 2021, 3:07 pm   #9
robot797
I know, that is why I translated the pin 4-5 to the 3-6 or 6-7
robot797 is offline
Old 18th May 2021, 3:17 pm   #10
Station X
Station X's Avatar
If you set up the tester to test say a PL504 (heater on pins 4 and 5), which sockets of the IO valve holder on the tester have the heater voltage (27V) on them? Socket pins number anti-clockwise when looking into the socket.
Old 18th May 2021, 3:22 pm   #11
robot797
I just tested all the pins
there is 30V between pin 2 and 7 on the tube tester
robot797 is offline
Old 18th May 2021, 3:24 pm   #12
robot797
I am using card 1167 btw
and it sais 10A
robot797 is offline
Old 18th May 2021, 5:00 pm   #13
Station X
Station X's Avatar
The diagram is a bit confusing, but as far as I can see:-
Pin 2 of the IO plug is wired to socket 4 of the B9D socket.
Pin 7 of the IO plug is wired to socket 5 of the B9D socket.
Pins number clockwise when looking at the bottom of a valve or viewing a valve holder from under the chassis.
Pins number anti-clockwise when looking into a valve holder from the top of the chassis, or looking at the solder side of a plug.
I hope I got that right. It's easier to visualise it than it is to write it down.
Old 18th May 2021, 6:04 pm   #14
robot797
I cant find any way to connect how you say it is
unless I used the 8 pin tester socket as the 9 pin tube socket
could you please draw it out for me
robot797 is offline
Old 18th May 2021, 6:11 pm   #15
Station X
Station X's Avatar
You need to make an adaptor consisting of an International Octal Plug and a B9D socket interconnected as per Ed's drawing.
The International Octal plug plugs into the tester and the valve under test plugs into the B9D socket.
Old 18th May 2021, 6:21 pm   #16
robot797
yes I know
and I have both
but I cant make the connections because the drawing just are bad
I have restored the whole tester with minimal help
and I am mad at myself for not being able to make a simple adapter
I mean I have had to make a few other adapters and they all work
but this one I can't get it to work
robot797 is offline
Old 18th May 2021, 7:23 pm   #17
Station X
Station X's Avatar
How is your adaptor wired?
Old 18th May 2021, 7:29 pm   #18
robot797
I can't wire it because I don't understand the drawing.
robot797 is offline
Old 18th May 2021, 11:17 pm   #19
PJL
Attached is the output from my Mullard Tester simulator - it is available in the forum somewhere.
It shows what function each of the pins is being tested as, the corresponding pin number on each of the valve sockets, and the expected voltages. In this case two connections are made for each of the control grid, screen grid and cathode which is not normally the case!
Check the holes in your card match the image in the attachment.
PJL is offline
Old 18th May 2021, 11:42 pm   #20
Station X
Station X's Avatar
That looks pretty straight forward and confirms what I said in post #13.
It isn't difficult to work out the other connections.
For example the screen grids, pins 5 and 6 of the IO, go to pins 6 and 7 on the B9D as per Ed's drawing.
ID:	234403   Click image for larger version
