17th May 2021, 4:36 pm | #1 |
Quad 33 edge connector
Currently restoring a Quad 33 and have noticed that one of the pcb's is lose in its socket, these are the blue edge connector sockets not the earlier white ones that were adjustable. Any advise on tightening or replacing the socket? If not would something like building up solder on the traces be advisable?
Thanks |
17th May 2021, 4:53 pm | #2 |
Re: Quad 33 edge connector
If the board is single sided a few layers of Sellotape on the back may help.
17th May 2021, 4:55 pm | #3 |
Page 3 of the service manual. Just don't go too far...https://www.dadaelectronics.eu/uploa...ice-Manual.pdf
Never Leave Well Enough Alone... |
18th May 2021, 4:12 pm | #4 | |
18th May 2021, 4:52 pm | #5 |
Sorry, I have not seen one for a long time, but I thought the only difference was the later ones were gold plated, but still loose their 'grip' over time and use?
I would not add a solder flow to the pads, that just pushes the fingers even further out. Armstrong 52x suffer the same issue and they are solder coated. Merlin's tape on the rear might well be enough of a solution?
19th May 2021, 11:12 pm | #6 |
I remember my 33 blue connectors were (are) a very loose fit to the board but keeping the board fingers clean and lightly 'servisoled' and they have never given a problem.
Alan |
20th May 2021, 9:39 am | #7 |
I may have a spare motherboard with the sockets on . I will have a look and let you know
Dave
Any tool can be used as a hammer but a screwdriver makes the best chisel |
