Old 13th Apr 2021, 1:12 pm   #1
ECC83x2
Default Grey RS capacitors.
Hello everybody,
I'm looking for some grey-sleeved RS capacitors, .0047 (4n7), 250v. Length is slightly more than 10 mm. By chance, does anybody have some to sell?
I appreciate any help you can provide.
ECC83x2 is offline   Reply With Quote
Old 13th Apr 2021, 9:04 pm   #2
Julesomega
Julesomega's Avatar
Default Re: Grey RS capacitors.
I don't know what type of RS capacitors you want: do you know the voltage or the dielectric type? or what period your equipment was made?
- Julian
It's good here
Julesomega is offline   Reply With Quote
Old 13th Apr 2021, 9:35 pm   #3
Restoration73
Restoration73's Avatar
These were a former type of foil capacitor made by Erie in a grey or green heatshrink
covering. The main problem with these is the welded leads break off at the ends of the
capacitor body. A better modern type would be ;
https://uk.farnell.com/vishay/mkt181...ial/dp/3289329
Restoration73 is offline   Reply With Quote
Old 14th Apr 2021, 12:25 am   #4
ECC83x2
Hello, thank you for your kind reply.
Restoration73: Yes, it is true, they were quite weak because the welding tends to snap off, but I'd need these to repair a device of which I'd like to keep the exact visual aspect.
Julesomega: they are identical to Restoration73's link, but in a grey heat shrink sleeve, with a blue writing '0047 250v'.
If anybody had some of these, or know where to get them, please let me know.
Old 14th Apr 2021, 2:33 pm   #5
unitelex
Originally Posted by ECC83x2 View Post
Hello everybody,
How many do you need? I have a few in the original RS packet. 0.0047 500V 3mm diameter 12mm long
Best Regards
Chris
Last edited by unitelex; 14th Apr 2021 at 2:41 pm. Reason: added size and voltage rating
unitelex is offline   Reply With Quote
Old 14th Apr 2021, 3:14 pm   #6
ECC83x2
Hello unitelex, thank you very much for this. Yes I'm interested, I just sent you a PM.
