Old 21st Jan 2008, 6:53 pm   #41
Keith
Keith's Avatar
Default Re: R1155: Removing/replacing three gang tuning condenser
David,
Before this gets too far off topic, here is a suggestion. Try using a low voltage buzzer (i.e. electromagnetic type) and a battery to find the shorting vanes. In a darkened room you should be able to see sparking where the vanes are making contact.
Keith Yates - G3XGW
VMARS & BVWS member http://www.tibblestone.com/oldradios/Old_Radios.htm
Keith is online now
Old 12th Feb 2008, 12:23 am   #42
restorer
I found your comments following a search for gang shorting problems. My problem is the RF section at the very low freq end. Discovered during calibration. I have proved that the moving plates do not short at the visable point with a paper feeler Gauge. It seems that the problem may be at the base of the fixed vanes. There is considerable flux filling the plates at the connection point which may have caused some corrosion growth. This can only be resolved by removing the complete unit for inspection.
restorer is offline
