15th May 2017, 3:48 pm | #1 |
Graticule illumination?
Recently I replaced a blown 6v3 filament bulb 'on' indicator in on of my scopes with an LED. The scale illumination was powered from the same supply. I mused that in nearly 45 years of owning a scope (starting with a Hartley 13A...), and using one at work for much of that time, I have never ever turned up the graticule illumination, but all CRT scopes are fitted with it.
When would it be used? Regards, BC |
15th May 2017, 4:01 pm | #2 |
Re: Graticule illumination?
Is it not to show the graticule when taking film camera photos?
Obviously this is unheard of these days. |
15th May 2017, 4:18 pm | #3 |
It's useful for photos, yes, and also for normal use depending on the lighting conditions and what sort of colour filter, if any, the scope has on the screen. When using a scope in low light I find the graticule illumination especially helpful. Just looking around at the 3 analogue scopes within sight of my desk, I realise I habitually keep the graticule illumination on when I'm using them just to remind myself they're switched on! There isn't always a visible trace, especially if I've got a scope set up to trigger on some particular event, or I'm using a differential input with a big offset.
Chris Chris
15th May 2017, 4:55 pm | #4 |
