Reply
Old 2nd Aug 2025, 8:32 pm   #1
Chris55000
Default Quickie Oscilloscope Circuit Technique Query!
. . .Just a quickie one on Oscilloscope Circuit Techniques I haven't seen described anywhere to my knowledge!
. . .Can anyone suggest the advantage of using a dual–gang X or Y Shift Potentiometer with the ends of the tracks cross–connected and the wipers connected either directly or by series resistors? It crops up in many of the manuals for the older Solid–State British designed Oscilloscopes!
. . .If anyone can point me to a descriptive reference to this method of wiring Shift Controls I'd be very grateful – the Home Built Oscilloscope I'm currently working on uses this technique for the "Y Shift" but not for the "X Shift" control!
Chris Williams
Chris55000 is offline   Reply With Quote
Old 3rd Aug 2025, 10:08 am   #2
Craig Sawyers
Craig Sawyers's Avatar
Default Re: Quickie Oscilloscope Circuit Technique Query!
Because the deflection plates are driven differentially, so you need a differential x and y shift control, in both directions. For that you need a cross coupled shift design.
See Tektronix golden era Horizontal Amplifier Circuits and Vertical Amplifier Circuits from
https://w140.com/tekwiki/wiki/Concepts_Series
Craig
Doomed for a certain term to walk the night
Craig Sawyers is offline   Reply With Quote
Old 3rd Aug 2025, 12:20 pm   #3
Chrispy57
Thanks for that reference Craig, but having had a quick look I'm a bit mystified, perhaps you can help? I started by looking at the Horizontal Amplifier option;-
https://w140.com/tekwiki/images/d/df/062-1144-00.pdf
PDF page 22/108
P18 Fig. 2.1, R11 - one half of a dual ganged 20k potentiometer labelled Horizontal Positioning, has both ends of the track connected to ground ie the potentiometer is shorted out. The other ganged half of the dual potentiometer, R3 20k, has -150V and ground on either end, which makes sense.
Chris
Chrispy57 is offline   Reply With Quote
Old 3rd Aug 2025, 1:16 pm   #4
Neutrino
Neutrino's Avatar
This might be a mistake. PDF page 28 (P24 Fig 2.4) show the ends of the track connected to PLUS and MINUS. This potentiometer is only used in EXTERNAL mode when the other gang of the potentiometer is not used.
PDF page 64 (P60 Fig 3.12) shows the ends of the HORIZ CTR potentiometer tracks cross connected.
Neutrino is offline   Reply With Quote
Old 3rd Aug 2025, 1:21 pm   #5
G6Tanuki
G6Tanuki's Avatar
Craig
Yes you need a differential offset voltage, as you turn the shift control away from the centre position you need the voltage on one deflector plate to go up, and the voltage on the other plate to go down by the same amount. Hence the dual cross-wired control.
"It's not true that I had nothing on. I had the radio on!" -Marilyn Monroe .
Reply
