| Sets and Parts Wanted (private buyers only, no swaps) If you need help obtaining components, sets or equipment, post a message here. Private buyers only - no traders. No swaps. |
#1 |
Does anyone have a 2.5H smoothing choke they would sell. I need one for a valve PSU.
#2 |
You might want to specify what DC current the choke needs to be able to handle. The Hammond 159T is available new from here https://www.mouser.co.uk/ProductDetail/Hammond-Manufacturing/159T?qs=MDqvSWII5j9mkYkiMaDjgA%3D%3D (and possibly other suppliers) but its maximum current is 300mA. If you need more than that then you'll need a larger choke which'll likely cost more.
Cheers, GJ
http://www.ampregen.com |
#3 |
Its for the HT output powering an R1155 which I am told draws around 50 milliamp
#4 |
Administrator
Multiple posts deleted that were not offering the item requested.
See https://www.vintage-radio.net/forum/showthread.php?t=206646 |
#5 |
This - https://primarywindings.com/product/10-henry-100ma-dc-choke/ though not 2.5H will do the job. A few more henry's will reduce ripple. Check the power supply design to make sure though.
Andy.
#6 |
I will have a look as I think I should have a pair of maybe 1940s made but until I dig them out won't know the ratings.
Will let you know in next 24 hours. Rob
Sorting my very large amount TTL & LINEAR ICs. Message any wants, you might be surprised! |
#7 |
From the information given in one of the earlier deleted posts, it appears the rating needs to be 100 milliamp
#8 |
I found them and probably far too high inductance as one measures as 17.5H with 444R, the other 19H with 418R winding resistance.
Pretty heavy as well. Message me if any use, probably far too much inductance for your psu but I hung on to them for maybe vintage triode amp builder people as they look the part from that era. Rob
#9 |
Many thanks to all who replied but I think I am now sorted so thread can be closed
