Reply
Old 26th May 2025, 6:09 pm   #1
JoeDoyle
Default Sony KV-1320UB MK1 Power on/Screen fault
Hi all
When powering on this set snow appears with no signal as expected but then an uncontrollably bright screen with lines going across it appears, then the snow reappears 20 seconds or so later and it behaves normally. What could possibly be causing this odd fault? Also, if I power this set off when this fault starts and turn it back on soon after it's OK too. Please can someone point me in the right direction? Many thanks, Joe
JoeDoyle is offline   Reply With Quote
Old 27th May 2025, 1:42 pm   #2
John123
Default Re: Sony KV-1320UB MK1 Power on/Screen fault
Hello Joe,
The symptoms you describe sound like typical bad capacitor behaviour. Check the flyback boost cap and caps surrounding the line-output transformer, RGB drives, CRT neck board, etc. Also check for dry solder joints especially in high-heat areas of the PCB.
Given the age of the set, it may be pertinent to re-flow the solder to all pins of the line-output transformer with quality leaded solder. Always good practice with most sets, even relatively modern ones.
As always, the necessary safety precautions when working with a live TV chassis. We don't know your skill level so if you don't feel confident, perhaps try a request in the 'Repair and Restoration Services Wanted' section of the forum.
Regards,
John
John123 is offline   Reply With Quote
Old 31st May 2025, 10:15 am   #3
JoeDoyle
Thanks John,
I will do as you suggested, there’s a cluster of 160v capacitors next to the line-output transformer. I do have a capacitor tester, so I’ll disconnect each one and test in turn. I will resolder all the pins of the LOPT too. I’ll report back on how I get on.
Old 22nd Jun 2025, 5:51 pm   #4
JoeDoyle
This is a bit of a late response, but I found the fault. R901 which forms part of the instant on circuit with the tube heaters, was removed to try and illuminate another fault but it didn’t work and I left it out anyway because I didn’t like the idea of having tube heaters on when plugged in. I reinstalled R901 and the fault ceased.
Old 22nd Jun 2025, 9:32 pm   #5
Maarten
Unless you start up the set while the cathodes are still cold, I assume?
Maarten is offline   Reply With Quote
Reply
