| Vintage Television and Video Vintage television and video equipment, programmes, VCRs etc. |
#1 |
Hi got this TV picture is good but no sound any thoughts of what problem would be connection to board and speaker looks fine.
#2 |
headphone socket would be a start if it has one.
Kevin |
#3 |
Is it definitely a UK set with 6.0Mhz sound?
#4 |
Yes UK model as have instruction manual and was sold in Portsmouth have tried headphones but no sound either.
#5 |
Check the PCB connections to the headphone socket - heavy handedness here can crack the print.
If all's OK there you'll need to trace the wiring back to the audio IC.
Glyn |
#6 |
Ok thanks will do that later.
#7 |
Might be silly question but do stereo headphones work in mono connection which I assume this would have.
#8 |
The Ingersoll XK512B service manual shows this as having a 6MHZ sound filter. TV band UHF ch 21-69, PAL colour system I. If you need a scan of the service manual please PM me.
Dave
#9 |
#10 |
Ok thanks.
#11 |
Has it got sound when the Radio function is selected ?
Ken G6HZG.
Life is not Hollywood, life is Cricklewood. |
#12 |
No sound from radio either.
#13 |
Ah, that narrows it down a bit then.
Any hiss from the speaker if you put your ear right up to it? Any buzz if you touch the wiper connection of the volume control? |
#14 |
No nothing at all.
#15 |
Not sure what you mean by wiper connection.
#16 |
Wipper is the middle connection of the Vol Pot. if you get a hum or buzz when touching, that, it would tend to indicate the Audio O/P is working.
As Glyn mentioned, its worth checking the Headphone Jack for damage or dodgy connections. Ken G6HZG.
#17 |
Yes tried that no sound at all have checked headphone connection looks perfect.
#18 |
I have the Saisho branded version of this set. Mine also had no sound. The cause in my case was that the speaker output coupling electrolytic capacitor had leaked and was open circuit. I don’t know the reference number, but it should be fairly easy to spot, particularly if you have the circuit diagram to hand. It may just be worth a look.
Chroma 04 |
#19 |
They may LOOK perfect but have you checked them with a meter? Measure the speaker connections through the headphone socket back to the output stage.
#20 |
Thanks for all your help guys but think this is a bit beyond me as don't know enough about the technical side of things.
