| Vintage Computers Any vintage computer systems, calculators, video games etc., but with an emphasis on 1980s and earlier equipment. |
#61 |
I would at the very least resolder all the legs of X401, X402 - thermal expansion / contraction, or physical vibration, over the years, may have caused one or more invisible cracks in the solder around the transistor pins.
#62 |
Agreed with Sirius, the fact that moving the leg of the transistor almost fully corrected the problem points to dry/cracked joints around those transistors.
#63 |
Hi
Yes I have had a look and there was a crack in the solder I have reflowed both transistors. I have tried it with the C64 I got with it but still not filling the screen any ideas what to try now. |
#64 |
May just need the vertical height adjustment adjusted now - when it originally broke down, probably all sorts of things got twiddled initially to try to make it work.
#65 |
Hi all.
Had the back off and twiddled the adjustment and it's perfect I just would like to thank everyone who has helped me to get this working and will no doubt be posting again on here soon as I still have some other vintage computer stuff to get going. Many, many thanks |
#66 |
Well done getting it going, it sometimes takes a while but I admire the fact that you never seem to give up, you always keep going and get there in the end.
