| Television Standards Converters, Modulators etc Standards converters, modulators anything else for providing signals to vintage televisions. |
#1 |
hi, I have lost the power pack to my aurora converter and I have found one that can supply the voltage but it has a rating of 1200mA, I wondered whether this would be okay to use as I don't want to risk damaging my converter!
Thanks! |
#2 |
According to the Aurora website it needs 250mA, so a 1200mA should be more than enough. I use the universal Maplin one, which comes with loads of different plugs.
Make sure you set the polarity right, although the converter is said to be protected against reversed feed. |
#3 |
Bigger is fine. I use a cheep and nasty unregulated psu from a market stall with mine with no ill effects whatsoever.
Jay
The light at the end of the tunnel is probably the headlight of an oncoming train |
#4 |
Thanks for that! Having turned the aurora on I have no sound through the set. This is with the tone and input, I am quite sure it isn't the set as I can hear rustling when I turn the volume pot and also mobile phone interference, I wondered whether there was a way to reset the aurora or try a method to see if it works again?
Thanks! |
#5 | |
To be absolutely safe, use an in-line fuse rated at 315mA. Rich
#6 |
Its not the amps that kill ,its the correct voltage that is priority.
#7 |
True, but beware of the cheap unregulated wall warts that will output a higher than rated voltage when not heavily loaded. This will cause excessive dissipation in the Aurora.
6.3v on my heaters is no longer enough to get me going in the morning!!
#8 |
Completely agree,it does need to be correctly regulated and i believe earlier in the forum it was stated they will run cooler on 9 volts.
Decent ones are cheap enough with 1.5--12Volt settings on.
#9 |
I agree that the Aurora is best run on 9v, I use a 1a regulated psu that I have measured at 10.3v with no load, this drops to 9.6 volts when running the Aurora.
A higher voltage can be used, but will make the Aurora run hotter, which may reduce it's life expectancy. ![]() Mark |
#10 |
I use the PSU from my Pure Evoke2 DAB radio. It's the correct voltage and polarity. The Aurora runs only slightly warm after its been running for hours.
#11 |
I have just found a cheaper wall wart lying around rated at 300mA with switchable polarity and voltage. I have checked the voltage output and by switching down to 7.5v output it feeds 9.6v into the Aurora which is now running nice and cool
