| General Vintage Technology Discussions For general discussions about vintage radio and other vintage electronics etc. |
#1 |
I recently acquired a Weller TCP iron rated at 45W, 50V. This belonged to a former GPO engineer and had a GPO type plug fitted. I've tested it on 50V dc and it works fine. Was the 50V exchange supply ac or dc?
Alan G6PUB, BVWS |
#2 |
DC from a battery.
The transformers supplied to enable these irons to be used on a mains supply were obviously AC.
#3 |
48V was the standard Telco exchange voltage both here and in the USA.
In times past I installed a bunch of Cisco and Wellfleet routers in Telco local offices that were fitted in 23-inch standard Hubbell racks (with their US spec mounting screws) and they all ran off 48VDC.
"It's not true that I had nothing on. I had the radio on!" -Marilyn Monroe . |
#4 |
A purely resistive heating element is, of course, equally happy with AC or DC.
#5 |
Yes I obviously realise that but the contacts in the Weller TCP will be subject to more sparking erosion with dc.
Alan G6PUB, BVWS |
#6 |
Both 48 and 50volts are quoted for exchange batteries.
This thread is no exception. Would I be right in thinking that originally 24 lead-acid accumulator cells were used in series, and the extra 2v was a consequence of them being permanently on float - charge?
-- Graham. G3ZVT |
#7 | |
#8 | |
The room I remember at an exchange in East London had tiled floors and walls, with semi-open topped black troughs containing the electrodes and acid, all linked up with flat copper bus-bars. Lots of warning signs about explosive gases, and some powerful fans too.
