Old 4th Aug 2025, 11:33 pm   #1
xrhonda91
Default EICO 330 FET RF signal-generator manual?
Hello All,
I've recently purchased a "later version" EICO 330 RF signal-generator which uses a FET for the oscillator. Have not been able to find the operator's manual though after thorough on-line search here in the States. Several sites offer the earlier 330 PDF. Is there anywhere in the U.K. that may have this needed manual?
Thanks very much for any help!
Name:	330 FET version.jpg
xrhonda91 is offline   Reply With Quote
Old 5th Aug 2025, 4:49 am   #2
Terry_VK5TM
Terry_VK5TM's Avatar
Default Re: EICO 330 FET RF signal-generator manual?
I think you're going to have to hope someone has the correct manual and sees your message.
Note that it was also sold under the EMCO brand as the Gen-RF 1 Solid State FET RF Signal Generator (picture here http://www.allsold.ca/emco-gen-rf-1-solid-state-fet-rf-signal-generator-10417) but likewise, no manual or schematic seems to be available.
If you can get some good quality square on pictures of the top and bottom of the PCB, I may be able to draw the schematic from them.
Terry VK5TM
https://www.vk5tm.com/
Terry_VK5TM is offline   Reply With Quote
Old 5th Aug 2025, 7:28 am   #3
Terry_VK5TM
Well persistence pays off, it was also sold as the Monacor SG-1000, this is a translation of a German user manual + a schematic.
Terry VK5TM
Old 5th Aug 2025, 9:31 am   #4
FIXITNOW
FIXITNOW's Avatar
and this which may also help
FIXITNOW is online now   Reply With Quote
Old 5th Aug 2025, 11:21 pm   #5
xrhonda91
Excellent, Terry---thanks VERY much! I had wondered if this Korean-made unit was sold under other names, but couldn't find anything even using Google image search (here in the States). How did you discover this info? I had already planned to "reverse-engineer" circuit if nothing could be found in a reasonable amount of time as I've done before with a few other seemingly rare and undocumented items. Certainly appreciate your quick help!
FIXITNOW---Thanks for your response, but that PDF is for the early, much more common version.
Old 6th Aug 2025, 1:16 am   #6
Terry_VK5TM
Combination of not using common search engines and switching off AI searches is part of it and having a few favourite places to look.
Image search (not Google) led me to the Emco version which told me it was a badge engineered thing.
Then limiting searches to regions outside the US, ie Europe, Asia etc - it showed up in Germany.
It shows up under quite a few different names and as has been proven when looking for the Eico version, the model numbers have been reused on later versions as well - manuals also are non-existent for them.
Terry VK5TM
Old 9th Aug 2025, 3:13 am   #7
Terry_VK5TM
I've redrawn a clean copy of the schematic and added a couple of notes I found elsewhere.
Terry VK5TM
Old 14th Aug 2025, 4:03 pm   #8
xrhonda91
Thanks much, Terry---just now saw this. Downloaded PDF to folder.
Have an 8-digit LED freq counter module I need to find a compact enclosure to fit which will sit on top of generator. Odd that the 1984 EICO catalog listing states that maximum output is 300,000 uV and the Monacor manual text says 30 mV. I am seeing approximately the latter with good & clean waveform.
Old 14th Aug 2025, 10:06 pm   #9
Terry_VK5TM
I reckon one of those might be a misprint, although they are two different circuits.
Terry VK5TM
Copyright ©2000 - 2025, vBulletin Solutions, Inc.
Copyright ©2002 - 2025, Paul Stenning.
