| Vintage Television and Video Vintage television and video equipment, programmes, VCRs etc. |
#1 |
Back in 2022, after returning from working abroad, I went to power on my B&O Beovision MX2000—but nothing happened.
About five minutes after plugging it in, I heard a faint sizzling noise, followed by a loud bang and some smoke. I had a strong suspicion it was one of the filter capacitors—and it turns out I was right. Fast forward to summer 2025 and, after a house move, I finally found the time to open up the set and take a proper look inside. Sure enough, there’s a visibly exploded capacitor on the main power supply board. The issue is that the TV is now completely dead. I’ve been told this particular capacitor shouldn’t completely prevent the TV from powering on, but in my case, it clearly has. No lights or anything and it never comes on. I’ve tested the three internal glass fuses, as well as the plug fuse, and all of them checked out fine. Beyond testing fuses, I’m a bit stuck on what else could be causing the problem. Before 2022, the set was working perfectly fine. |
#2 |
When that cap went S/C it could have blown the print off check underneath for damaged print, have you got any mains supply going to the power supply ? Unfortunately I am not that familiar with the later B&O sets.
But some one on this Forum will be able to offer more advice. Ken G6HZG.
Life is not Hollywood, life is Cricklewood. |
#3 | |
The MX2000 is from around 1986 so its 40 years old now. |
#4 |
It sports a Thomson ICC3500 (ICC3 second generation) chassis, though this PCB would have been a B&O product. The TV is mains separated by a large transformer. The primary circuit shouldn't be too complicated. Maybe first measure around the transformer, see if any power is getting to it.
Also, is it really dead and not in standby? |
#5 |
If there really are no signs of life (no standby LED etc) then the problem is likely to be on the upper of the two microprocessor panels which are arranged vertically below the tube neck. The memory battery leaks and rots the tracks away, the goo can also ruin the small transistors and diodes in this area.
I'd start here first, especially if there is any corrosion. Start with the 5.2V line and the reset generator, this is normally where problems begin. I've never had to scrap an MX2000 (or an M20) for this fault but repairs can be complicated as the tracks are quite thin. The MELF-type resistors on the print side can fail too if their end caps begin to rot away. Moral: Don't store these sets long-term with the memory batter fitted. |
#6 |
Sounds quite plausible, especially since 'no signs of life' was the first symptom after plugging it in, even before the smoke grenade went off.
