25th Oct 2013, 12:02 am | #1 |
Location: CH3, Blaen Plwyf Transmitter, Aberystwyth, WALES
Tube Cameras & associated faults
I was going through my collection of old tube cameras. On powering up one of them, an Hitachi GP-4D (circa 1978?) with a tri-electrode vidicon tube just displayed a blank raster in the viewfinder CRT.
So I opened it up to see how many leaky caps I could find, which seemed surprisingly unleaky looking. I did notice however that on applying power, the tube at the base went distinctly purple. Now I remember reading this does happen with thermonic devices, but I can't remember why, does this indicate a fault with the tube itself or the voltages driving it? Thanks!
405 line TV, 1936- 1985 2007.........to the present day |
25th Oct 2013, 6:11 am | #2 |
Re: Tube Cameras & associated faults
Good morning,
Hows about a bad coupling cap or Anode-overload ? I hope the tube is not gassy! Happy week-end, German Dalek
And now something completly different: MARC BOLAN, he was/is the real king of Pop Music! |
25th Oct 2013, 10:22 am | #3 |
That tube does not look healthy to me, the start up glow of the heater should be a reddish yellow colour.
If you hold your finger near the tube target ( remove the lens) there should be a lot of interference and patterning if the video amp is working ok. good luck. |
25th Oct 2013, 8:58 pm | #4 |
Usually when any tube glows purple as brightly as that it is not far from going to air.
I had an audio output pentode that glowed purple and a month or so later it went to air. |
25th Oct 2013, 10:47 pm | #5 |
Thanks all for your input (no pun intended!). I did try touching the target area but got no response. Anyway, looks like the tube then, I suppose these are unique vidicons being tri-electrode? Oh well, another non working static display then!
26th Oct 2013, 11:30 am | #6 |
"reelguy" has an Hitachi HKC770 up for grabs - similar tube maybe?
