8th Feb 2014, 1:15 pm | #1 |
Marconi TF144H Signal Generator Problems
Hi I am having problems with the Marconi AM Signal generator Mod TF 144 .
There is no output on ranges J and K but on L there is some, low to nothing. I am aware of the corroded wire giving problems on the LF ranges I have successfully repaired some of the other ranges new osc valve tried HT set ok LT set OK . Anyone had dealings with this model , Mick. |
8th Feb 2014, 1:34 pm | #2 |
Re: Marconi sig gen problems
There have been several models of TF144 sig gens. Some completely different to others, so the suffix letter is important.
8th Feb 2014, 2:56 pm | #3 |
Thanks David it is a TF144H series 2. The one with the big coil turret.
17th Feb 2014, 5:46 pm | #4 |
Re: Marconi TF144H Signal Generator Problems
Still in trouble with this one, it works on the LF ranges and the high range but no output on other ranges; tried the valves the HT and LT set OK.
Anyone got a coil turret that I could borrow just to eliminate this part? Mick. |
18th Feb 2014, 9:30 pm | #5 |
Hi Mick
I know that provided a reply to me over the problems with my TF144 so maybe I can help out? I can't lend you the coil pack but I do have the service manual if it's any use and may be able to help with voltage readings. After I had repaired my TF144 I found that the output did vary on some of the bands and this was fixed by adjusting the Set ALC (RV101) a little after I had replace the 5763. Maybe that could help in you case? Let me know if I can help Steve
Steve Mc |
18th Feb 2014, 11:41 pm | #6 |
Hi Steve thanks for that.
As you probably gathered I am at my wits end with this; everything checks out as per manual, voltages etc. At the moment I am waiting for a new osc valve. I did try a supposed new one but I have my suspicions. I will let you know how I get on, regards Mick. Last edited by Mike Phelan; 19th Feb 2014 at 9:42 am. |
