19th Apr 2009, 11:39 pm | #1 |
Philips 10 watt Novosonic amplifier repair
Hello everyone.
I've finally got around to repairing (or attempting to repair at least) a Philips 10 watt Novosonic amplifier. This has been cluttering my shed for the last eighteen months or so, and consists of two matching wooden cabinets (each 3 feet high and 15 inches square), one containing the amp and a Philips record deck, the other a 12" bass speaker and a 7" treble unit. I have a curry's brochure from 1957 and this was the most expensive item listed, and is detailed in their hI-fI section. The whole thing seems extremely well made. Basically I want to get this working to see if the sound quality warrants the effort I'd have to put in to bring the cabinets back up to scratch, as they're both in fairly poor cosmetic condition. It was powered up by the previous owner prior to me collecting it, so when I got it home I did switch it on (not as cautious as I am now!) but with little effect - although with the volume up to max there was a faint, poor quality sound from the speaker. I've not powered it up since. I've purchased the service data, which is quite extensive at seven pages, and have decided to replace the coupling caps and all the Dubliner electrolytics (see attachments), plus a few out-of-spec resistors. The first thing I want to do though is bring the mains wiring up to requirements. I was very surprised by how flimsy this is considering how much the unit cost. The on/off switch is also defective as it tested live with a neon screwdriver - luckily I was cautious enough to have some rubber between my finger and the switch! So my first question is this: should I replace the mains lead with two core flex or do I need three core so the chassis can be earthed? Also (and I hope this isn't too silly a question), which lead is which? Does the live connect to the voltage selector, or mains transformer? The current lead looks like speaker cable. I've tried to capture this area in one of the attached images. Any help would be much appriciated. Thanks Keith |
19th Apr 2009, 11:46 pm | #2 |
Re: Philips 10 watt Novosonic amplifier repair
Just thought I should mention the valve line-up: EF86; ECC83; EL84x2; EZ81.
Cheers Keith |
20th Apr 2009, 7:44 am | #3 |
The live should connect to the mains switch. You should earth the chassis so use 3-core cable. If you want it safer then you need to replace the switch with a 2 way one and switch both live and neutral, and add a fuse into the live wire...Peter
20th Apr 2009, 9:11 am | #4 |
When you say the mains switch tests live presumably you mean the BODY of the switch rather than the contacts which should be live? That being the case the whole chassis will be live because the body of the switch is electrically connected to it.
BE VERY CAREFUL.
20th Apr 2009, 9:49 am | #5 |
The valve numbers begin with E, which usually (except in a few, rare cases, distinguible by a power transformer which is barely any bigger than the speaker transformer -- so not like yours) means a non-live chassis. It would definitely be worth fitting a 3-core mains lead and earthing the chassis.
By the way, in the UK, where all plugs are non-reversible, double-pole power switches are really no safer than single-pole, and may be less safe under fault conditions (if the live contact welds up, but the neutral contact is still functional, the appliance seems to be off but is still live; this can happen in cases of live-earth short, and I've seen it with my own eyes).
20th Apr 2009, 11:03 am | #6 |
Always switch Live. A double pole switch is a good idea, as is a fuse on the Live end after the switch. And a 3A fuse in the plug.
Caps need changing as do out of spec resistors. This is probably in Push-Pull by the way. Sockets and Plugs can also be a problem here. And meter out the transformers just to be sure. You do not need a matched pair of EL84's by the way. They match themselves very quickly. Cheers, Steve P.
20th Apr 2009, 12:47 pm | #7 | |
I would rather use a double pole switch, and risk the live contacts welding than the rather more common "backwards mains syndrome". Of course it's impossible to eliminate EVERY risk.
20th Apr 2009, 11:53 pm | #8 |
Thanks for your quick responses, guys. Much appreciated.
I think I'm a little confused with this whole switch thing. When I say the switch tests live, I mean the toggle part itself rather than the body of the switch, which was behind the fascia panel - this has only been powered up whilst all the parts were in situe, not with the amp removed. So that being the case, is the switch at fault as no part of the wiring is connected to the chassis? And as you say AJS, this is not a live chassis design. I think I'm confused with this because on all the stuff I've worked on so far, the colour coding of the mains cable made it obvious what was live and neutral; also the terminals on this switch are not marked + or -. Another thing that I'm confused by is the rectifier valve. The service data shows this to be an EZ81, but the one I removed was an EZ80. Judging by the dust build-up it doesn't look like it’s been touched for decades, so I'm not sure if this was a mistake or not. And would it still work with an EZ80? Cheers Keith |
21st Apr 2009, 7:39 am | #9 |
The only parts of that switch which should be live are the two solder tags on it. In fact with the switch in the OFF position only one of the tags should be live.
A suggested by several posts in this thread fit a three core flex with the earth wire connected to the chassis and the switch in the live wire. For additional safety fit a double pole switch. Switch weld ups are unlikely. If you're worried about reversed wired mains sockets, then get one of those plug in socket testers from your local DIY store and test all your sockets. LATER EDIT. Having re-read the post I see that it's the actual toggle of the switch which is live. That being the case it definitely needs changing. It would appear that the toggle is electrically insulated from the body of the switch, so anyone touching the earthed chassis and the live toggle at the same time will get a shock. In a correctly wired installation this should trip the RCD.
21st Apr 2009, 8:24 am | #10 | |
Personally I think with push-pull EL84, the EZ80 is running near it's limit. Rich.
22nd Apr 2009, 11:47 pm | #11 |
Thanks Graham, I don’t think I made it clear at the start that the toggle was live, but now I’ve read the posts a few times it’s much clearer what I need to do.
I've also discovered that a 2 amp fuse exists in the body of the voltage selector, although finding a replacement wouldn't be easy as it doesn't appear to be a standard size - I've read a few posts here about how Philips gear isn't always very easy to work on, as they weren’t very conventional with their designs. Regarding the rectifier valve, I've found an EZ81 that I removed from an old tape recorder, so when the time comes I'll use that - thanks Rich. So far I've replaced all the caps, and am about to rewire the mains and fit a new switch with a view to testing it at the weekend (when I've dug out the two units from the back of the shed!). I'll let you know how I get on. Keith |
23rd Apr 2009, 7:44 am | #12 |
There may be a terminology problem here. I would describe the toggle part of the switch as the metal lever arm that you touch to operate the switch. If this is live then the switch is most definitely faulty and needs replacing...Peter
23rd Apr 2009, 9:22 am | #13 |
Peter,
Strickyly speaking that's the dolly. I don't think I've ever come across one that was live, although it might be if the chassis onto which it's mounted is. That would be a lethal combination. Alan |
23rd Apr 2009, 11:11 pm | #14 |
Interesting, from what I can make out, 'toggle' appears to describe the mechanical sprung action that holds the switch in the on or off state.
23rd Apr 2009, 11:23 pm | #15 |
Peter,
That sounds plausible, although I'm still not clear which part of Keith's switch is live. Keith, be careful. Alan |
24th Apr 2009, 1:55 am | #16 |
Yes, it was definitely the toggle/dolly that tested live. I must admit I found it strange at the time, as the body of the switch is mounted on a wooden fascia panel that's at least 10cm away from the chassis.
I will be careful Alan - I've been extra cautious since receiving a nasty shock from the deck of a so called 'restored' Dansette some time ago. I'll post some photos of the whole thing when I retrieve the two units from the shed at the weekend. Hopefully it'll make it easier to see what I mean. Keith |
24th Apr 2009, 8:05 am | #17 |
I have a number of these Bulgin switches in stock.
Firstly, I must remember to check them for leakage before use Secondly, Keith, if you'd like to keep your amp original, you'd be welcome to one of them (assuming that they're not all leaky). |
24th Apr 2009, 11:08 pm | #18 |
That would be great, thanks.
I'll send you a PM to arrange. Thanks Keith |
25th Apr 2009, 12:01 pm | #19 |
Interestingly, I've checked my switches, and they measure about 50 Megs between the dolly and any of the terminals. Not enough to do any harm, but may well give a tingle if not earthed. Not what I'd have expected from a Bulgin component, I have to say - perhaps the insulation degrades over time?
25th Apr 2009, 12:19 pm | #20 |
Keith
In equipment using mains transformers where the chassis is not earthed as in your amp. it is very common for sufficient leakage and / or capacitive coupling to exist between mains live and chassis to light a neon screwdriver. Only a few microamps are required. See here for a recent post on this subject http://vintage-radio.net/forum/showt...t=leakage+neon So your switch may not be faulty. The best way to test the switch would be to use a Megger or similar to perform an insulation test on it. Hope this helps. John |
