Old 11th Oct 2008, 3:55 pm   #1
peter.sables
peter.sables's Avatar
Default Eddystone 640
hi
For my next project I've picked up a "not bad" Edison 640. Is there any pitfalls with this set that I should know about..
Thank you
Pete G4MRU
peter.sables is offline
Old 11th Oct 2008, 4:14 pm   #2
dave walsh
Default Re: Edison 640
If you mean the Eddystone 640 Rx circa 1947 Peter and not the famous inventor [although he was fairly electrical] I've coincidentally, just got one myself in a similar condition! It's still in Bognor Regis so I have not dug out various restoration articles yet that I know are around in the mags although I'm sure there will be direct experience available on here. Mine has a long history incuding twenty years or so out of the country and I even have the call sign of the first owner. It's complete with the original handbook so I should be able to do you a copy in due course, if you require it.
I told the seller that I last had one of these back in 1977 when a personal "credit crunch" forced it's sale although the overall econmy wasn't brilliant then either I suppose.
Cheers Dave W
PS If you do mean the comms rx we might be in the wrong section but I 'm sure the mods will sort it.
dave walsh is offline
Old 11th Oct 2008, 4:48 pm   #3
Brian R Pateman
Brian R Pateman's Avatar
Default Re: Eddystone 640
Dave is right, so I've re-located it to a more appropriate section.
Regards,
Brian
Brian R Pateman is offline
Old 11th Oct 2008, 8:14 pm   #4
XTC
Peter,
Check the "Useful Vintage Amateur and Military Radio Info (read only)" link, current in the read only section.One of the links from there is to the Eddystone User's Group site and there are numerous copies of "The Lighthouse" which you can access on-line.
Of course, you may also get help on here if someone has special knowledge, but the EUG site and publications are well worth a look.
Pete.
XTC is offline
Old 11th Oct 2008, 9:06 pm   #5
peter.sables
hi.
Thanks.
Yes that's a good start. Yes it looks much used. So will be nice to power it up again....
Pete
Old 11th Oct 2008, 11:26 pm   #6
Skywave
Arrow Re: Eddystone 640
Hi!
Eddystone 640; I've renovated a few of these.
Apart from the usual replacement of old capacitors & high-value resistors, check that the metallizing on the EF39 IF amp. is intact - otherwise the IF amp. will go unstable.
If you re-align the IF amp., don't forget to do it on the phasing crystal frequency.
Apart from that, four specific headaches that spring to mind are:
1. The AF amp. is on its own little sub-chassis, making measurement of the 6V6 electrode voltages impossible. I've always removed this sub-chassis, replaced all the Rs & Cs en-bloc & then re-assembled & re-fitted it. Less hassle in the long run.
2. If re-stringing the drive mechanism is required, this is difficult without the info.
3. It's rare for the IF gain pot. to give trouble, but if it needs replacement, it's a problem: it's a wire-wound reverse-log. pot.
4. General maint. is difficult in places, but in-line with most Eddystone radios.
Good luck with it!
Al. / Skywave.
Skywave is offline
Old 13th Oct 2008, 6:55 pm   #7
peter.sables
Thank you all.
Right its project time on this Eddystone S640. It's now on the bench and I've not put power to it yet. It looks as though its not been used for some time and all bits are as should be. Yes I can see I'll need three EF39 s as the red is almost off. The cord is ok. Bit worid about the main trasformer as I see some black pitch that has dripped out! Could be ok but not checked.
Some info:-
Eddystone S640
Regd. Pat. 57443
EY 0722
Thanks Dave yes I'll need any copy's you can give. Think they will be very handy.
Pete G4MRU
Last edited by Sean Williams; 13th Oct 2008 at 7:36 pm. Reason: Pitch starts with a P........not B :-)
Old 15th Oct 2008, 12:03 am   #8
peter.sables
hi
Inspection complete. After a slow run up the set works very well. Stations heard even without a antenna fitted. Apart from the three valves that really should be replaced. Work needs to be done one the switches (they do not work every time) , the tuning and band spread mch. are in need of some grease. They have that dry feall to them. But also all the pots are scratchy.
So. question is...
How do I fix the switches and how do I fix the pots...
I suppose in the end it only need some T L C.
Pete
Old 20th Oct 2008, 10:00 pm   #9
Skywave
Short answers are:
Pots.: try switch cleaner. If that fails, replace them.
Wave-change switch: switch cleaner.
Toggle switches: replace them.
If you have a need (& are stuck ) for a replacement 10 k-ohm RF gain pot., send me a PM. I have a stock of suitable (not original) w/w 10k reverse log. types: these are a common feature in Eddystone valve receivers.
Al. / Skywave.
Skywave is offline
Old 25th Oct 2008, 11:03 pm   #10
peter.sables
hi
Thanks for that. I've sent for a set of valves for it as they looked shot. I only need one valve then it can be turned back on. Ha new switches,,, OK I'll look out for them. Al. I'll get back to you when I've got it up and running. It has though cleaned up really nice.
Very nice set..
Pete
Old 26th Oct 2008, 11:19 am   #11
Skywave
Switches: have a look at Farnell 120-3336; product code 2BL63-63. £4.96 ea.
Traditional chrome toggle, DPDT, 3A a.c., 6A d.c., approx 1/2" dia. through-chassis fixing, solder tag wiring.
I'm sure that these are ones I've used in the past when overhauling Eddys.
Two further thoughts . . .
As 'standard build', there are no fuses fitted in the PSU.
I strongly recommend fitting fuses in the mains. transformer pri. and HT sec'y. The d.c. HT current is about 75 mA when the set is warmed-up.
Check the front-panel mains switch. In some Eddys., only one side on the incoming mains is switched - and sometimes that is the "N" . I always fit a DPDT switch to break both sides on the incoming mains, with heat-shrink fitted over the switch solder tags. As with all Eddys. with this type of layout, it is too easy for a finger to come into contact with the wiring to the the mains switch when doing maintenance - and if you've forgotten to switch off / disconnect at the mains source . . .
Al.
Skywave is offline
Old 27th Oct 2008, 11:40 pm   #12
peter.sables
hi Al.
Thanks for the very good info. I've printed it off. Never thought to look for fuses.
Pete
Old 28th Oct 2008, 10:38 pm   #13
squier
the phasing control switch can be a bit dodgy too causing signals to "leak" around the phasing xtal rather than through it!. Otherwise they're not a bad little set. Must get around to fixing mine sometime.
Mark
PS: I wonder if you're the same Pete Sables from Skellow that I knew 20 odd years ago?
squier is offline
Old 30th Oct 2008, 1:20 am   #14
Skywave
Yes - I've had that trouble too (faulty phasing switch). And - ISTR - it's a rather fiddly job replacing it, too
Al.
Skywave is offline
Old 30th Oct 2008, 1:36 am   #15
Skywave
The above Posts on phasing reminded me of selectivity issues I've experienced with this receiver . . .
Not that it's a maintenance issue, per se, but I do find that for Amateur Radio ssb reception, the relatively wide IF of the 640 leaves quite a lot to be desired in the way of selectivity. (I've often contemplated wiring up an external Q-multiplier to help with this . . . maybe, one day . . .)
But - having said that - my other two main receivers for that purpose being an Eddystone 888A (double conversion, last IF 85 Kc.) and a Racal RA-17 (triple conversion, 100 Kc last IF), so perhaps I'm not being fair to this 60-year old veteran! After all, there wasn't a lot of ssb around in 1947 (date of manufacture of my current 640). And considering that is was designed and built just after the end of WWII, when stuff was scarce . . . .
Your thoughts are cordially invited . . .
Al.
Skywave is offline
Old 30th Oct 2008, 2:53 am   #16
MichaelR
MichaelR's Avatar
Al,
I agree with your sentiments, in fact the 888 and the Racal were not far behind timewise when they were designed.
The Military stuff I find a joy to work on and use and it is all credit to the designers that with some skill you can use designs that are over 60 years old on modern band conditions.
I think the Q multiplier idea would work very well and worth a try
Mike
MichaelR is offline
Old 30th Oct 2008, 9:23 pm   #17
peter.sables
hi All.
New valves and switches arrived and fitted. Looks really nice. I cannot report on how well it works yet. But Ill let you know. But so far it works fine. Im hopping to marry it up with my Tinker box Mk3. So thinking that for CW it will do the job.
Thanks every one for your help... brill.
Pete
Old 31st Oct 2008, 1:27 am   #18
Skywave
"How well it works yet . . ."
Just a quick report about that - hopefully, by way of encouragement
Apart from one particularly nasty example that came my way, the few I've overhauled have all come pretty close to the published specs. after the necessary work had been completed. (Which, of course, really says something, considering the age of these radios ). 'Specs'. - such as sensitivity, signal/noise ratio, image rejection, and similar. It's the image rejection spec., at 30 MHz, that seems to be the most difficult to obtain, although I usually end up with a figure that is fairly close.
It would be nice to see a pic. of yours when it's all done.
HTH
Al.
Last edited by Skywave; 31st Oct 2008 at 1:29 am. Reason: add comment on pic. at end
Skywave is offline
Old 31st Oct 2008, 1:40 pm   #19
peter.sables
Hi
Not a report yet (but it will come) This is just some pics as I got it. The only bit that I think needs a look at is a capacitor has been cut but no sign of from where!! (Black arrow is the capacitor and white is the cut end)
Pete
ID:	20953   Click image for larger version
ID:	20954   Click image for larger version
ID:	20955   Click image for larger version
ID:	20956   Click image for larger version
Old 1st Nov 2008, 1:05 am   #20
Skywave
Hi Pete -
Well one things for sure - it's either an originally-fitted component with one end cut or a later added item! If original, C58, C59 & C60 seem likely candidates: a study of the cct. diag. should reveal all. However, looking more closely at your large-scale photo, I think I can see one or two other components that don't look like they are in the right place / right connections, either
A thorough check-out of all the wiring / component fit would seem in order.
TTFN.
Al.
Skywave is offline
