Old 9th Feb 2020, 8:57 pm   #1
BrianAllen
Default Connecting Philips N4308 to external amp
Does anyone know how to connect the above tape deck to an external amplifier (not using the live connection on the deck)?
Thank you.
BrianAllen is offline
Old 9th Feb 2020, 9:06 pm   #2
Ted Kendall
Default Re: Connecting Philips N4308 to external amp
Use the 5 pin DIN in/out socket. Signal on pins 3&5, screen to pin 2.
Ted Kendall is offline
Old 9th Feb 2020, 9:09 pm   #3
BrianAllen
Is that the record/phono socket?
Old 9th Feb 2020, 9:11 pm   #4
BrianAllen
Sorry, radio/phono socket.
Old 9th Feb 2020, 9:27 pm   #5
ajgriff
ajgriff's Avatar
Tape recorders are not really my thing but weren't there at least two versions of the N4308 with different DIN sockets? I'm not sure about the Radio/Phono socket. Sounds like two inputs to me. Hopefully someone has an N4308 and will be able to advise. Hi-Fi Engine has a service manual which might help but it is in Dutch. Should be possible to follow the schematic though.
Alan
ajgriff is offline
Old 9th Feb 2020, 9:38 pm   #6
BrianAllen
This is my /55 model. The stereo connection has a live pin to be used with a Philips accessory cable, so I'm thinking that it will be the radio/phono connection.
Old 9th Feb 2020, 9:40 pm   #7
Ted Kendall
Radio/phono should do the job. It's an in/out socket.
Old 9th Feb 2020, 9:41 pm   #8
BrianAllen
Thanks Ted
Old 10th Feb 2020, 2:28 pm   #9
DMcMahon
DMcMahon's Avatar
I wondered what you meant Brian, by the live connection reference, I now see that there is a -26 volt internal supply fed out to pin 5 of the Stereo DIN socket.
DMcMahon is offline
Old 10th Feb 2020, 9:15 pm   #10
BrianAllen
Yes, the live connection was one of the very first things that was pointed out to me by other members; so much good advice/information on here.
Old 11th Feb 2020, 5:27 pm   #11
DMcMahon
DMcMahon's Avatar
Yes fantastic broad range of knowledge and experience across the whole forum !
DMcMahon is offline
