13th Mar 2008, 9:52 am | #1 |
Stubborn tuning slugs
Can anybody provide practical advice or advise techniques to "free off" IF tuning slugs that will not turn. The slugs are not broken and I would like it to remain that way and I need to adjust the IF's because I have had to rebuild the whole IF section. Mike |
13th Mar 2008, 10:20 am | #2 |
Re: Stubborn tuning slugs
Hello Mike, I find that lighter fluid works very well. Gently drizzle it into the core and within seconds the slugs should begin to move.
Neil
13th Mar 2008, 11:01 am | #3 |
Mike
I find that a swift squirt of Servisol 10 softens any wax locking the core and lubricates the thread when making adjustments, preventing the core from jamming up on debris. Ron |
13th Mar 2008, 1:00 pm | #4 |
Ear wax remover.
Leon. |
13th Mar 2008, 2:12 pm | #5 |
I've used ear wax remover and Three-In-One on occasions. It's best to set IFTs so that gravity helps. You really only want whatever solvent you use in the core, not anywhere else. You can always add a drop more later if you need it, but getting rid of excess is a nuisance and it might do damage.
The other thing is get or make an adjustment tool which fits the slot properly, that way you distribute the pressure evenly and there's less chance of crumbling the core. Pete. |
13th Mar 2008, 5:39 pm | #6 |
And arising from this Thread - if you do have a cracked core / tuning slug - what's the best way of removing it?
Al / Skywave. |
13th Mar 2008, 5:42 pm | #7 |
Grind it out with a dentist's burr held in a Dremel type tool.
13th Mar 2008, 6:56 pm | #8 | |
A tip that I came across some years ago may be helpful: use two adjusting tools, applied to opposing ends of the core simultaneously, whenever possible. You can then apply much more force to the tools, thus keeping them in the slot/hole more firmly, whilst removing the frictional force between the core's thread and the coil former: the core magically becomes very much easier to turn... |
13th Mar 2008, 7:13 pm | #9 |
13th Mar 2008, 7:19 pm | #10 |
Soldering iron tip on the core for a few seconds - shifts them every time!
13th Mar 2008, 8:55 pm | #11 |
Yes, but be certain that what you are touching with the iron really is a ferrite and isn't a plastic carrier. This happened to me a few years back with a PCR.
The other thing which happened, also with that PCR, is that the core seems to turn easily, but if you look carefully, you can see that the tube it's in also turns. The tube and coils are glued to a paxolin carrier and the glue can fail. Just turn the core and you will break a Litz wire, probably close to the coil. I smelt a rat and didn't fall into that trap. The other thing I've had happen is that the plastic carrier can break and luckily it was just a careful job with superglue, but it could have been tragedy. It didn't take much to break it. Pete. |
14th Mar 2008, 10:56 pm | #12 |
Thanks everybody for your suggestions. The ingenuity of man always amazes me!
After much struggle I had to resort to the dremel and grind them out . It looked as though somebody had heavily glued them in place , they would not move.Even this task was not easy Mike |
15th Mar 2008, 7:14 am | #13 |
I have a Pilot model 10 with one core that stubbornly refuses to move. Fortunately the alignment is good so I've left it alone. However I did have a look inside the transformer to investigate why it was so tight.....the coil former has SHRUNK! Maybe this is due to heat but more than likely the material it's made from (although it looks just like Paxolin). There is no way the core is going to move up or down. Anyone else come across this? I'm leaving it as it is anyway as the alignment is good.
Rich.
15th Mar 2008, 10:43 am | #14 | |
These had definitely been glued with some sort of evostick type glue. It was defininetly not wax. I was glad of the dremel suggestion ( station X) as with the dentist burr I was amazed at the degree of control I had with the removal of the core. regards Mike |
15th Mar 2008, 12:43 pm | #15 |
Older equipment seems to have slugs sealed with wax which is generally fairly easy to remove. With more modern gear they seem to be sealed with some kind of paint or a blob of silicone sealant which is much more difficult to remove. Then of course some slugs have a strip of rubber embedded in the side.
On the whole I prefer sets where the slugs are attached to a threaded rod. True the slug sometimes detaches itself from the rod, but it can be glued back on again. Where such slugs have locknuts I don't bother to reseal them, This facilitates future readjustment and as long as the set is with me I know the phantom twiddler hasn't been at work. The threaded rods in the AR88 Comms receiver are sealed with a substance which goes rock hard. I think it may be shellac. Don't try to drill out a slug with an ordinary twist drill. There is a risk it will "catch up" and split the slug. This then splits the former and may destroy the winding. If a slug has split it is sometimes possible to use a pair of very small thin nosed pliers or tweezers to pick out the bits, or crush them to make removal easier. If a slug absolutely refuses to move you can check the alignment by introducing brass rod into the core to lower the inductance or another slug to raise it. This is easier with inductors having a single winding and a single core. More difficult with IF transformers.
16th Mar 2008, 12:23 am | #16 |
16th Mar 2008, 4:13 pm | #17 |
In one set I restored with a totally immovable slug, I was able to add a very small amount of additional parallel capacitance in order to bring the coil to the required resonant frequency (the frequency needed to come down). As a "trimmer" I just used about 1" of parallel twin bell wire and chopped little bits off it until it was correctly tuned. It took a few goes to get right, but it was a very non destructive bodge - far better than breaking something.
If the frequency had to go the other way, I would have changed the fitted parallel capacitor for one of a lower value. Leon. |
17th Mar 2008, 5:31 pm | #18 | |
Trevor
