Old 5th Jan 2008, 4:03 am   #1
Top Cap
Top Cap's Avatar
Default Battery holding sponge for Hackers etc
I had just purchased a Hacker Herald, all complete except for the circular sponge pads that should be on the lid to hold the batteries snugly in position.
I wondered "How the hell am I going to find those" and just kept them in mind. Whilst burning some CD's on the PC the circular packing pieces in the CD cake caught my eye. "Hey, what about those? Nice thickness with reasonable give".
So I tried a pair using some double sided tape so I can change them for real ones if I ever get the chance. Certainly not a trick for the purist but they do the job!
Les
Whether the Top Cap is Grid or Anode - touching it will give you a buzz either way!
Top Cap is offline
Old 5th Jan 2008, 12:46 pm   #2
Darren-UK
Default Re: Battery holding sponge for Hackers etc
I just replace them with those self-adhesive felt pads you can get from most stationery shops etc. They look nothing like the originals but do the job and are hidden inside the radio.
I've also bought sheets of thin foam as used for seat padding and cut out the shapes I want. Not easy to cut the shapes out neatly and uniformly though.
I'd not thought of the CD packing pieces though, must remember that one .
Darren-UK is offline
Old 5th Jan 2008, 12:54 pm   #3
Brian R Pateman
Brian R Pateman's Avatar
Corn plasters?
Regards,
Brian
Brian R Pateman is offline
Old 5th Jan 2008, 3:56 pm   #4
Mike Phelan
Mike Phelan's Avatar
I've used a sheet of foam offcut from local market and used a set of cork borers (hole punches) for the circular bits.
Mike.
Mike Phelan is offline
Old 13th Jan 2008, 4:54 pm   #5
chipp1968
chipp1968's Avatar
I found a foam type ring as packing inside a pack of CDR disc s that came in a cylinder type pakaging , might be bigger than you want ,is about inch and quater diam. just a thought , though you might be able to punch some out of similar material using copper tube ?
chipp1968 is offline
