4th Jul 2012, 2:41 pm | #1 |
Roberts RMB up and running
Hi All
RMB 48267 is up and running. Dead on arrival it was a case of replacing the old wax capacitors, 3 of the valves and repairing broken MW aerial wires (detached where they solder to the frame pins, not broken). So now she is up and running. The only thing I have been unable to do is adjust some of the cores in the inductors as they are siezed - any tips on removal and replacement sources? Rog |
4th Jul 2012, 4:53 pm | #2 |
Re: Roberts RMB up and running
Try trickling some lighter fluid down into the cores, this should loosen the wax enough to enable you to adjust them.
Neil
4th Jul 2012, 5:11 pm | #3 |
Or even ear wax softener drops.
4th Jul 2012, 8:58 pm | #4 |
Thanks both - I'll give it a go.
Rog |
